Yes you don't need special tools or even air tools. It's an easy job.
Not as long as you can hold the case. They are torqued to 80 ft-lbs just shy of what a lug nut is. My buddy and I thought we could hold it by hand. Neither one of us were as manly as we thought.So it's not that hat to get the ring off?
That IS a really great writeup! I'm still a little pessimistic - nearly everything I've read about autolockers is that they're not good for DD TJs. Too much noise, clicking, chirping, etc. I live in FL, the land of the U-Turn, so that's a concern. BUT, this isn't a project that I'll get to before next year, most likely. If installed in the front as in this example, safe to assume I'd still deal with the noise even when in 2WD?I did one years back with basic tools and it wasn't too bad. The only thing I would suggest is that you have a bench vise to hold the carrier.
Here is a great right up:
Aussie Locker - Dana 30 Front Axle Installation Write-Up
what a 'rockin write up! been sitting on my aussie building up my courage.. thanks..I did one years back with basic tools and it wasn't too bad. The only thing I would suggest is that you have a bench vise to hold the carrier.
