So I picked up a 95 YJ for my wife a month or so ago-4.5 Lift and 33s. It has a 4.0 and the 3 Speed Automatic. She loves it!!
Recently the automatic occasionally starts off in 3rd gear it seems instead of first. I can start out in Low and it is fine or in 2nd and it starts off in 1st gear and will shift into second no problem. I can then swap it into D and everything is fine. It only does it occasionally.
I did some Forum searching and research and did the following today:
-Changed Fluid and Filter-decent amount of metal on the magnet, but no big chunks.
-I adjusted the TV Cable several times.
The two things above did help and the trans is starting off in high gear far less, but still doing it once and a while
Anyone else have this problem? I don't think the 32RH has any solenoids or anything, but I don't know too much about these Jeeps as I just started playing with them.
Thanks in advance for any suggestions.
Well whatever it was wasn't good. The trans was shifting find for 15 minutes today and then something happened..it started to whine loud and now no forward or reverse gears..so time for a rebuild I guess
