Status
Not open for further replies.
1 - 20 of 82 Posts
I am trying to make a decision before I order 2007 Unlimited Wrangler Rubicon. I need to know what is PRO and CON between automatic vs manual transmission.
Thank you for advising if you have answering this question.
Mark
Mark
Manual is way more fun. :D Seriously though, nothing beats using the gears to decend a steep hill, but then again, it sucks having to shift in the middle of trying to climb that hill... Gas mileage would be better with manual. More low end power with a stick. Plus it's harder to chirp the tires between first and second with an auto. ;)
If you do a lot of city driving go with the auto. If you do a lot of highway or a mix of highway and city, then I would go with the manual. Off road, a lot of it is just personal preference and how you drive. IMO
Either way you go, I'm sure you will love it. It's a Jeep!
i have a 5 speed manual. how many speeds in the 07 auto and manuals?
manuals last longer once you submerge them in water.
compression braking off road or around town is a nice to have feature.
you can go for a very long time with little to no maintenace with the stick.
aren't manuals generally shorter for more driveshaft length when lifting said jeep.
while out rock crawling i wish i had an auto for easing up rocks instead of constantly feathering the clutch.
around the city autos are a nice feature to have.
autos torque converter do add alitle more torque to things.
how much are oil and filter changes plus an occasional clutch adjustment on an auto?
i'm sure there is more of each but it's a start.
I also have manual and i live in a city. I'm used to it so i dont care much that i have to shift. As scumby says you gotta feather the clutch on trails. To be honest the 4 low is such a slow speed you dont even need to press the clutch most of the time. At least i dont. As recomendations go if you drive this thing to work and back and talk on the phone while driving I would say get an auto but if you like to have fun on your way home, manual is the way to go. You will get use to changing gears in about a week and after you wont notice it much. Anyhow keep us updated
· Retired Moderator
I see a lot of answers here that I think are off base. A stick is more fun? Please! I have a stick and I know that I would be happier with an auto. Someone up there said a stick is better in water. That's crap. Test drive both and get the one you want, but the auto is the way to go, imo.
Better mileage too.
· Retired Moderator
buy what you want. i don't mind my manual but you might be happier with an auto.
i have heard that manuals are less prone to damage (in water also)
amerijeeps favorite magazine (JP ;)) said they are less prone to damage. there magazine may suck in some peoples opinion but it doesn't mean they don't know a few things about jeeps.
· Retired Moderator
They certainly do suck and they think we suck. Ever see the issue where they talked so badly about jeep internet forums and the people who use them? Now why do you suppose that is?
Anyway, drive your manual through water all you want.
I love driving manual, sometimes i wish i had in auto, but that is very rare..
Manuals are pretty simple when it comes to servicing, but then a new clutch and labor are atleast $500...
It all depends on what you like...
· Retired Moderator
nah i quit the water stuff. nah i never saw that issue. petersens 4wheel and offroad is pretty good though. or maybe i should try j rations
· Retired Admin/Mod
With the ruby either the auto or the manual is fine. The auto in the rubicon is going to have the same crawl ratio (or darn close) to the std CR in a non ruby 6spd or Tj 5spd. So you will have about 45:1 or so. Which is darn good. I have a 5spd, but if I get another jeep it will be the auto.
Manual versus Automatic
All the input regarding manual versus automatic transmissions are good.
I would add the following:
Clutch versus torque converter. Clutch is a direct coupling between motor and transmission. This is advantages for downhill work. The direct coupling also gives a little better fuel millage. The down side to the clutch is when a lot of start stop driving is done the clutch will get hot. When hill climbing and feathering is needed the clutch will get hot and can fail under extreme conditions. Think of the cluth as a break pad holding the motor torque to the transmission.
The torque converter is a hydraulic fluid coupling which provides smooth coupling between motor and transmission by means of hydraulic shearing of the fluid. This sheering accounts for the fuel milage loss. A second item is the heat caused by heat sheering. When doing hill climbing and a lot of start stopping the torque converter fluid heats up. If this heat is not removed transmission failure occurs.
Heat in the automatic transmission fluid can be removed using coolers. The heat generated in the clutch is more difficult to remove under continual clutch application. The manual clutch relies on the heat sinking properties of the flywheel and pressure plate for its cooling. This means that if you heat up the clutch and can leave it engadged (foot off the clutch) for a while the heat will be drawn out of the clutch plate.
Now we get to the automatic transmission versus the manual. When looking at the gear tooth contact between the gears on a manual transmission you will notice that on the transfere of power there is only a gear and a half tooth contact between gears. This is a week point for manual transmissions. In Automatic transmissions a planetary gear system is used alowing three sets of gears transfereing torque at all times. This allows for significant tooth contact between gears. This is why drag cars use automatic transmissions.
I prefere automatic for strength and manual for fun.
hmmm never knew that thks for the info:punk:
.......... When looking at the gear tooth contact between the gears on a manual transmission you will notice that on the transfere of power there is only a gear and a half tooth contact between gears. This is a week point for manual transmissions. ......
I respectfully disagree...Because of the clutch packs and the packaging, designers have to go as minimal as possible with the planetary systems.. Hence the teeth of the latter are very fine and need more contact area (3 gears) to transfer the load which the planetary system will provide for. Shock loads in a auto transmission are more easily absorbed whereas in a manual you only have the damper springs in the clutch disk..
Manual transmission gears are much sturdier and trust me they can transfer quite a load with the helical concept. Also the bearing pattern ratio over the surface of the tooth flank is much greater than in the planetary systems..
I haven't seen too many manual transmission with the teeth sheared and I have seen a lot of high mileage Mustang, Firebird and Corvette transmissions. I have noticed lots of pitting. (that is another issue of high loads with lack of lubing and bad involute profiles..)
Also the auto has a stall speed torque convertor and the hydraulics will also prohibit any heavy shock loading..
Again that might be true for drag racing.. But Jeeps are no drag racers..and I have no issues that you prefer auto transmission but I make exception as to the reason why..
Just some background music..
Hey Antigoon. I dont understand what you meant by it. Could give it in newb language what that mean. I have an auto and so am reading through this thread...:confused:
Outside the technical jargon just read: Strength wise, your auto is as good as your manual..
Preference should be based on your usage..
Sry for being technical in my previous reply. Load transfer in gearing is quite complex and needs to be understood before making statements that one is better than the other....
Oh ok.. Thanks.. I was getting worried reading through the thread..:D
Manual
Have had 'em both in JKs. Manual all the way. Auto is only 4 speed, and have to push a button to lock out 4th, can't shift all 4. Acceleration with auto is not nearly as good as with manual. Pick the right gear before you start wheelin' you shouldn't need to shift in the middle of a hill. Caveat: rear end ratio makes a lot of difference, get at least a 3.73, 4.10 is preferred.
Jeeps and Corvettes should be red and should have manual trannys.:cool:
:):) Heh Heh, Well I've had corvettes and jeeps--
Mine has to be yellow and Auto for the jeeps-snow/shale/hills and 6-speed manual's for the corvettes
I've just been that way since my first vette, a 1962 fuely, although it wasn't a 6-speed, twas a 4-speed and it was a color, called Fawn Beige
:rofl::rofl: JIMBO
:rofl::rofl: JIMBO
1 - 20 of 82 Posts
Status
