whats up dudes, ive been swapping a 97 aw4 into my 94 sahara.
it used to have a TF999 3 speed on it column shifter , blew up ..
been doing the aw4 ever since.
i have been following stu olsons website and using all of his different links to reference for my swap...
Site Index
the tranny comes with a TCU. my YJ was hydraulically shifted...
first thing i did was solder in the connections for the TCU and the 6 and 8 pin connectors to the PCU. i used "Moab 4x4 aw4 into YJ " for wiring reference its inside of the site index of stus website .. he has the diagrams to do it .
PCU connection
wires to 6 and 8 pin connectors..
TCU behind black wires. i havent taped the wires together
then put in a tranny cooler..
then i put in the transmission..
then i had to cut the input shaft of the transfer case to make it mate with aw4. transfer case in
Discussion Starter #2
problem number uno! aw4 is in , now the CPS isnt the same on both trannys. different mounts and different connectors ..
as you can see
top one came in the YJ, bottom one is from AW4.
what can i do in order to make the CPS for the AW4 to connect to my YJ?
do i need to cut the YJ cps get the other end of the aw4 cps and solder it to the YJ cps cables?
and also there is a mount missing for the CPS cause its open where the cps goes.. like a plastic thing is missing.. not sure where to get a plastic thing.. any help would be appreciated thanks!
