just did this, and, if you do your home work, not that bad. There is a mounting bracket that the AX15 uses that is not present on the AX5. You can buy new, or, used is just as good. Also, depending on the slave cyl. that you have, you may need to get one of those as well. Some use the external, some internal. So, you may have to get some new slave cyl lines.
