1 - 10 of 10 Posts
Not happy at all. I drained my transmission fluid in the Ax-5 and it's nothing short of disgusting. I can't post a picture up from my phone, but I will later on the computer.
Basically, I would like to know what kind of oil I can fill the tranny up with, ride around town once, and then re-drain again.
The 75-90w is pretty expensive, so I would prefer not to use that as the flush-oil. Is there something else I can use?
In addition, there are two 15/16th hex head bolts on the passengers side. One is lower and more aft. The other is above and more forward. They are diagonally from each other about 2 inches.
Which one is the fill plug?
I flushed mine with straight 30w....drove about 15 miles and then drained and filled with Syncromesh. the top one is the fill plug. I used a hand pump for an outboard motor lower unit that fit on the oil bottle. fill until it starts to flow out. it takes about 7.4 pints.
If you try to fill it through the bottom one……..
I don't mean the plug on the bottom of the tranny, I mean the bottom plug as in the plug just below the other plug on the side of the tranny. There's two of them just inches apart and I wanted to make sure one of them wasn't a "Do Not Remove" plug lol.
The lower of the 2 should have "do not remove" stamped on or near it. But the plug that is higher is the fill plug.
You can use all most any kind of oil for a flush, as long as it isn't a high detergent oil. 10W30 would work fine.
10w30 would definitely be cheap enough to buy for a couple flushes. I was reading that some guys use that in the tranny all the time. Would that be ok mix fluid types bc my Ax-5 always had gear oil in it?
So what I'm asking is that ok to use for a flush and then go back to GL or Syncromesh?
Yes, use the least expensive 10W30 from Walmart. Drive 20 miles, then drain it while it's warm.
Sounds good I might even do a double flush though, it was really nasty lol.
1 - 10 of 10 Posts
