if you have front and rear axle you more likely to have both (30 - front, 35 - rear) :D
The d35 is a weak axle too so dont put on to much stress like by putting tires larger then 31 on it. 33's would be pushing it. If you lock it be prepared for it to blow.
Ian
The dana 30 in the front has a metal fill hole plug on the differential housing plate you can unscrew with a ratchet
the dana 35 in the rear has a rubber fill plug on the differential housing plate.
Both of the axles have a Axle Shaft Spline Count of 27
