There will also be a metal tag on the differential covers which will state your gear ratio , and if the tags are missing you can pull a cover and look at the outside of the ring gear the ratio is stamped there also.
If you have a 1995 with a 2.5 5 speed tranny and everything is factory you have Dana 30 front axle and a Dana 35 rear axle with 4.10 gear ratios in them.
