Have you blown any oil out the vent tube? Could it be kinked or the vent on top plugged up? Too much oil in pumpkin?
some saharas came with the 44 stock. A guy I work with has one.Your Sahara came stock with a Dana 35. When replacing the seals the axle needs to come out and it should be obvious if there is a problem. The bearing could be bad and that would show on the axle shaft as wear. That would cause seal failure. Also if the there is a groove worn in the axle from the seal lip, that could cause leakage. If you don't want to replace the axle, both problems can be handles with an axle repair bearing.
I had all the bearings replaced as well. So if the bearings were bad and then replaced that would cause an axle issue? Shouldnt he have seen that?
I had all the bearings replaced...could he have installed seals improperly? I heard these things are finicky?Your Sahara came stock with a Dana 35. When replacing the seals the axle needs to come out and it should be obvious if there is a problem. The bearing could be bad and that would show on the axle shaft as wear. That would cause seal failure. Also if the there is a groove worn in the axle from the seal lip, that could cause leakage. If you don't want to replace the axle, both problems can be handles with an axle repair bearing.
Check that first before replacing any more partsHave you blown any oil out the vent tube? Could it be kinked or the vent on top plugged up? Too much oil in pumpkin?
How does that affect the seals? Thank you!Check that first before replacing any more parts
would this put too much pressure on the new seals then? cause them to blow? Sorry this is new territory for me. Thanks guys!Have you blown any oil out the vent tube? Could it be kinked or the vent on top plugged up? Too much oil in pumpkin?
The vent is on the axle so when the fluid heats up and expands it doesn't pressurize the housing. If the vent is clogged the pressure can build and blow out the axle sealswould this put too much pressure on the new seals then? cause them to blow? Sorry this is new territory for me. Thanks guys!
He answered it.The vent is on the axle so when the fluid heats up and expands it doesn't pressurize the housing. If the vent is clogged the pressure can build and blow out the axle seals
It depends. If you have a Dana 35 the rear axle shaft rides on the bearing rollers. If the bearings go bad they will likely cause damage to the axle shaft where they come in contact with each other. On the Dana 44 the bearing is pressed on the shaft and if the bearing goes bad, it will just eat up the races most of the time. The axle shaft will be fine. Did you figure out which axle you have? Here is an extreme case of what happens to the axle on a D35 when the bearing fails. It will take much less than this to cause a leak.I had all the bearings replaced as well. So if the bearings were bad and then replaced that would cause an axle issue? Shouldnt he have seen that?
