I have 99 wrangler and have been running a Rock Krawler long arm kit for 6 years now. I installed an 8.8 in the rear and a HP Dana 30 in the front. I squared the axles and centered everything up. Upon acceleration, it goes straight and wells. The problem is, when I let off the gas, it feels as though the rear axle shifts rearward on the drivers side. The joints seem fine and the upper links are new. I can't figure this out. Amy help is appreciated!
You say the upper links are new. So, I assume you the upgraded triangulated 4 link and not the old 3 link with the weird upper "U with a post" that mounted to a tab on top of the diff' with one bolt. The only reason you'd have that kind of shifting is a bad Heim joint on one end or bad bushing on the other end.
