So after I swapped a g2 rear core 44 in, my abs and traction control lights are on. Every time I turn a little it sounds and feels like esp is maybe kicking in.
Any ideas on where to start diagnosing?
I tried to make sure my wheel sensors are connected to the wiring well but there seems to be some play in both. Is that normal?
Alignment/steering centered ?
For a rear swap? I didn't adjust the track bar or arms at all and it still looks centered. Also the lights are on before I go anywhere.
Just checked the codes, lost comm with tcm. Left rear wheel speed sensor circuit, Right rear wheel speed sensor circuit.
Are they swappable, if I accidentally switched them?
Not sure what was wrong with the sensors, connected them both as good as I could a couple times, resetting the codes and the warning lights went off.
Problem I was feeling actually seems to be the auburn ected diff...Maybe it needs to be broken in...
