1 - 9 of 9 Posts
Custom 9 Axles at Krawl Off Road
Our Turn 9 lightweight fabricated housing was designed from the ground up with the weight conscious racer in mind! Welded in internal bulkheads, unique to Currie housings, tie the face, the body and the tubes together, and, exclusive to The Turn 9 housing, the bulkheads are windowed for additional weight savings allowing the center to weight it at just 17.5 lbs.!
Tubes installed are 3" x .188" wall 4130 chromoly and this part number includes the Currie Pro-Touring full floater housing ends installed.
Currie fill caps are installed on all Turn 9 housings and drain plugs are optional. Housing is custom built to your overall width and pinion offset specs.
The Turn 9 is arguably the strongest & lightest fabricated housing design on the market!
We can help you order custom axles and size Call or Email us today!
Austin
1 - 9 of 9 Posts
