1 - 20 of 21 Posts
after birthday glow
ok so I'm thinking about doing some fun stuff in the next couple of days. but i need to know i have a old 85 chevy suburban 4x4, what axles are under it i looked around but found nothing on this. i would like to put the axles under the yj with a soa and maybe eventually even the motor but i dont know if those are the dana44's or not. i know their not 60's for sure but i want dana 44's any help with this would be great.
after birthday glow
well i would but their at the shop and i'm twenty miles away from em any guess what they would be
after birthday glow
ok yeah i think ur right on the 10 or 12 that's what i think they looked like now how good are they in comparison i know their probably better then the dana 35 under their right now but in terms should i hold out for a dana 44 or would these work OK for what i want to do
Hacks off Parts while Lit
from what i've heard, the 10 bolts were on the weak side. someone else should probably chime in on it though. it might not be worth the trouble of swapping in full widths for a pair of 10 bolts.
after birthday glow
Discussion Starter #7
ahh ok well if anyone else had anymore info that would be awesome but i'm curious what was weak on them the axles or the houseing ? i just want to be sure that in the end i wont regret this
after birthday glow
Discussion Starter #9
well the chart says the dana44 and the 10 bolt run the same ring gear size and does spline count matter that much i mean i have dabbled in axle stuff before but only to fix things and i think its only a few short of the 44 spline count
after birthday glow
Discussion Starter #10
so on a update i found a 10 bolt in the rear and a dana 44 up frount on the old burb it least I'm pretty sure that's what it was so the biggest hurdle now is getting my old man to let me tear her apart for the axle but my question now is if i put that under my jeep i know i need a drop pitman arm but what else (other then sye)
Administrator
The 10 bolt is the dana 35 of the chevy world.. don't waste your time and energy.. Go find a 14 bolt for $300 and be happy with life.
after birthday glow
Discussion Starter #12
oh i wasn't going to replace the rear with the 10 bolt i was just excited for the dana 44 was planing a 14 bolt or maybe just a 12 i don't think i will need a 14 but then again bigger is usually better
after birthday glow
Discussion Starter #14
yeah i am probebly just going to buy rear axle for it if it comes down to it
dont older chevy's use the push/pull steering setup? if they are, you'll need more than just a drop pitman arm. and werent they still passenger side drop in the mid-80s? if so, you're gonna need a new transfer case as well.......
after birthday glow
Discussion Starter #16
ah crap i forgot about the wrong side transfer case problem well now that just complicates it a little more don't it
like i said (and a couple others) there'll be a lot more work than its worth to swap in a 10 bolt
after birthday glow
Discussion Starter #18
well i wasn't going to do the rear 10 bolt but yeah. I'll probably just have to figure another way to get me some full sized axles. i really want to do spring over conversion but i want to put full sized axles under their so its all done in one shot.
its going to be wide and you're not really going to get a big step up in axle beef... yeah they are heavier duty but not by enough for the work... think about all the other issues like wheel bolt pattern, steering, etc... etc... this is the type of idea that sounds like fun when ur drinking beer and snowballs into lots of time and money before you know it and the results might not have been worth it depending on what you're looking for...
I have been thinking about trying to get some Chebby D60's.
I read that it's possible to adapt a D-300 t-case to an AX-15.
This would give me the passenger side drop.
Personally I wouldn't go through all that for D44's though.
A front D44 is only marginally stronger than a D30.
1 - 20 of 21 Posts
