1 - 13 of 13 Posts
Ok so when taking the top bolts out 2 broke one on each side how do I fix this I tryed to use a air hammer to brake off the weld but bent the hole it was welded to any suggestions
I just went threw this.. You need to jack up your body tub, grind tack welds of nuts then knock them off with air hammer. I then used teraflex rear shock bar pin elim kit ($25) and installed it with grade 8 hardware.
Remember the 2 body mounts in front of the gas tank.. Took me a few min to figure it out. I used a dremel with a cutoff wheel to cut into the tacks hold the nuts then air chisel to knock them off.
I poked my dremel through the hole where the upper tip of the shock goes and cut the majority of the tack weld off the nuts. I was then able to air hammer the nut the rest of the way off.
undo the body mounts and replace the upper shock bolts and nuts with grade 8 hardware ... its about a 1 hr job if you have air tools
But if I can get the welded nuts off I have inserts for the holes
Nutserts=devil IMO. After dealing with them for the skid for the t-case/tranny. I would prefer a nut and bolt and with the bar pin elim there should be no need to remove again.
Discussion Starter · #11 ·
That's the thing I got alot of money tide up into this all ready and if I brake one of the body mounts I don't have no more money and I kinda need the jeep back on the road soon other car has no life left
Retired Moderator
When I still used the stock mounting locations I just drilled the hole out and used a nut and a bolt. Kind of PITA to get the nut to stay, but the right combination of wrenches cut up hands and cussing got the job done. LOL
1 - 13 of 13 Posts
