So I've got the rear view mirror camera working and it's great. turns on when placed in reverse and camera is good enough for now. I placed the camera on the tow hitch for now using an old cap I had.
So now I want to be able to have the camera come not only in reverse but also if I turn on the rear view mirror camera when driving. I noticed that the video camera lead (the one that connects to the yellow RCA plugs) also had a red wire that appears to run the whole length of the yellow rca cable. I see 2" coming out of both ends. Any thoughts what this would be for
Cheers
Al
Cheers
Al
This red wire should be a power wire for your camera.
If you're wanting to have the camera come on whenever you want it to, then you'll need to set it up to be turned on with a switch, and not just when your Jeep is placed in reverse. You can actually do this several ways, dependent upon how handy you are electrically... a multi-position switch would be the easiest way..
good luck
Exco
Can you point me to a link on how to complete this mod or a quick run down on how it's done.
Again I'd still like it to come in in reverse but also be able to turn it on and off manually while driving
Cheers
Al
