The back up lights wont work replaced the fuses and bulbs and the switch they still dont work, and ideas and how costly will it be to fix?
On the 03 I had. the backup lights quit working a couple times. Ended up being the neutral/ reverse sensor in the side of the transmission.(5 spd) replaced it both times, lights worked.
You can use a test light and probe the wires at the reverse light and have someone else shift from reverse to neutral over and over and it should blink, if not youve prolly got a bad nuetral sensor or wiring.
