1 - 16 of 16 Posts
my 89 wrangler 4.2 with stock carb stalls, bucks, and backfires like crazy when accellerating. it idles great. have done nutter bypass , timing is set to 10 degrees btdc, new plugs , wires, dist cap, rotor, fuel pump and filter. i have removed cat and muffler and replaced accelerator pump and gaskets on carb. any ideas or suggestions. thanks in advance
Mileage on engine? Is 10• the correct timing for that engine? I would've guessed accelerator pump, possible the carb needs a good clean..
dont know actual mileage on engine, but fairly high. i dont know exacly the correct timing after nutter. factory calls for 9 degrees btdc. i have cleaned the carb more than once to no effect.
Had same problem with my carter carb. It would idle fine, rev up perfect. Put in gear and it would cough, spit and sputter. Tried a rebuild with no luck. Ended up with a MC2100 swap.
yeah thats what im thinking but kinda limited on extra money right now. just tryin to cover all bases on what ihave. did the swap fix your problems?
Check the 1/8" setting on the needles in the carb, sounds like your too lean .
solved my problems. got mine out of a junk yard & rebuilt myself. adapter plate from summit, carb kit and air filter form advance. about $110 total.
I ment on the stepper motor, when you did the nutter by-pass you should have set them out about 1/8 the best i remember. go over the nutter by-pass instructions, they say how to set it. good luck
ok wil do. i had extended them out as far as they would go. probably too far huh? i'll give the instructions another look. thanks for the help
Discussion Starter · #11 ·
i may have to check into that then. sounds like a cheap enough fix for a major headache. thank you for the help.
Discussion Starter · #12 ·
cant find anything about 1/8 on needles in carb. just says to remove stepper motor and fully extend needles and replace motor. did i miss something somewhere?
Let me look it up again, I'll get back, O and good morning!
Discussion Starter · #15 ·
nubby , i thank you very much for your help. i will sure be doing some changing. i had only seen john nutter's version before. anyway, have a good day, and thanks again.
good luck
1 - 16 of 16 Posts
