I see conflicting information from various websites on backspace measurement.
using the following data: 19x8 w/ +1 offset, this website shows 115mm (4.5"" backspace) measured from hub mounting surface to inside bead flange of the rim.
https://www.wheel-size.com/calc/?wheel1=285-70-17X7.5ET45&wheel2=325-65-18X9ET1&fcl=12mm&wcl=100mm&scl=12mm&sr=12mm
This website shows 5.0" from hub mounting surface to back of rim.
https://www.rimsntires.com/specspro.jsp
Do most rims/wheels factor 1/2" (12mm) lip to make up the difference?
Yes, there's a 1" tolerance considered for the lips. So, a 9" wheel would be calculated on 10", which means your centerline would be 5". So a +1mm offset would be just a hair above 5" backspacing.
