Your laundry list is pretty inclusive of any and everything that can go wrong.
15 mpg is about as good as it gets. The 7.8 city sounds like your rich at idle which is also indicative of pumping the pedal and flooding occurring. Methinks your Idle is a little too rich.
With the manual choke make sure you close it off within a minute or two of starting. It's only designed to draw fuel into carb on cold start. Once the temp gauge starts to register close it. Your ambient temp will affect this.
Colder block temps will require longer choke time.
Is your pressure regulator before or after the fuel pump? Might make a difference on fuel getting to carb from pump working too hard..or not. Just a theory/question in my head.
If it idles at 1krpms with no idle screw pressure your throttle cable my need adjusted out, vacuum leak or your needle seats may be damaged and too much fuel getting by. Especially if the needles are are most closed off.
