I have a 2000 Jeep Wrangler Sport, 5 speed. I went to start it, heard just a quick sound from like it was going to start but then nothing happened. Lights on the dash come on. I hear clicking but nothing. Popped the clutch and started right up. Got it home, shut it off and did the same thing as before. Any thoughts?
tranny in neutral, park brake set engine off jump 12 volts to small terminal on solenoid on starter if cranks briskly it ain’t starter or battery or battery cable connections
Narrows it down quick and costs nothing to do
All the wiring and switches in path of that wire to solenoid
Including clutch switch and ignition switch and the tiny plastic pin in the ignition switch that tends to break
