Bad wobble in steering, help please.
735 Views 3 Replies 3 Participants Last post by  Wharfrat
hey guys, just this morning I was driving to school my my steering wheel wobble just slightly side to side then stopped. after school I went mudding and went home. On my way to the store I was driving around 45mph and it started to wobble pretty bad. This time I noticed the jeep was shaking also. I have done no recent mods this started out of no where. I don't see any play in the steering. I don't think anything it out of balance but that very well could be the problem. Maybe dried mud on the inside of the rim making it unbalanced? any advice is appreciated. thanks.
· Retired Moderator
start with mud in the wheels. if you're ever going mudding. find a power wash place as soon as your done - before that stuff hardens - everywhere. mud insulates heat - heat is bad... and can throw wheels out of balance. check to make sure your wheel weights weren't thrown too.
Woke up this morning and cleared off the mud. Went for a test drive and the wobble is gone! thanks for the advice I didn't realize some mud could do that.
Mud is bad, and can cause a lot worse than that. I swore off of mud about 20 years ago once I realized what I was doing to the vehicle. The final incident was when it caused the front caliper to seize up completely. I had to pry the pads away from the rotor with a screwdriver, and then only use the emergency brake the entire 60 mile drive home.
