1 - 1 of 1 Posts
Hi, I understand from other threads that the OTC ball joint press is pretty dam good. I live in New Zealand - there is no OTC agent here, I could get one off Ebay but the freight would kill it.....
I have found a Automotive Tool supplier in NZ that markets a kit which has Dana 44 front diff ball joint removal adapters/ tubes, whatever you want to call them...
My question is will a ball joint press that is marketed as being the correct tool to remove D44 front ball joints also do a 1998 TJ Wrangler D30 front diff - the supplier here can't tell me....
It looks like the top joint is common between the D44 and the D30 front diff but the bottom joint part numbers are different - according to a moog listing I found on the net...
Any assistance would be appreciated!
1 - 1 of 1 Posts
