1 - 11 of 11 Posts
What about adjustable upper? And are those prices for 1 ball joint? Trying to figure out if I'm paying too much, ($250 for all 4 adjustable)
I can't see why you would need adjustable ball joints, unless your axle is bent.
Don't they help correct alignment? I am running 35s on stock control arms and a 3.5" suspension lift and 1" BL so I'm thinking they will help keep everything where it is suppose to be since I can't adjust my control arms. Maybe I'm wrong.
Commercial Member
Not sure how much caster correction you will get from adjustable ball joints.
For the cost, you might be better off getting a set of adjustable control arms.
Unless you need ball joints anyways and trying to kill 2 birds with one stone.... I'd still find out how much adjustment they will give you for the $$. Spicer ball joints (non adjustable) are under $100
I need ball joints anyway and since these are new but at a cheaper price I figured I would get them. For the moment if I were to get adjustable arms and could only get one pair I should get uppers correct?
Would I be better off just getting adjustable uppers for now and get non adjustable ball joints in the near future? I that joints I have now aren't totally shot but they are on their last leg.
1 - 11 of 11 Posts
