If you are also going to install fresh u-joints on the axle shafts, I'd go with Spicer's 5-760x which is a stronger direct-fit version of the 5-297 than the factory installed. Generally speaking, sealed -joints like the 5-760x are stronger and more durable than u-joints are that have a zerk fitting in the body which means there are grease channels running through the body which weakens it.
Go with Spicer. I 'upgraded' to Synergy last year, and am not happy with the results...less than a year, and already developing play. Yes, they've been lubed regularly, and with Synergy's 'special' grease...
I'll be installing a shiny, new set of Spicer ball joints, tomorrow.
I went with Spicers and installed them last weekend. Since the entire front end will be torn apart, consider doing the unit bearings, axle u-joints, and steering at the same time.
Jeep Wrangler Forum
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
