Anyone have any issues with fit near right rear shock and gas tank?
I had to put a Banks on cause of stock muffler was hitting right rear lower arm. Luv the Banks but cause of the oversize pipe it hits occasionally between this area. I have tried numerous times adjusting hangers with no luck. I did purchase new rear rubber support which helped a little.
Anybody chop after muffler? Great idead but concerned bout fumes.
no advice on the current tail pipe, but if you do cut the pipe after the muffler, at a minimum make sure you add a turn down as the hot fumes will melt the nylon gas tank if they are not aimed down
