Next moves? Agonizing on what to do with fenders. Looking at the Metalcloak Overland, but hate that you have to drill into Jeep. Also, they're expensive as hell. Also debating on installing rear view camera as I cant see ish out the back window... Anyway, appreciate any feedback, suggestions, comments!
Looks awesome! I have the same rig. Just planning out my upgrades now. Here's what I went with for the backup camera. Total cost was about $85 and has an factory look and feel. The only thing I did different was I mounted mine in the rear bumper.
Backup Camera Setup
Soldering iron
Solder
Heat shrink tubing
Wire to extend positive/negative from camera
http://www.amazon.com/Flush-Waterpro...MVQ1FA9NT5YRA2
Gino camera will have view and lines as seen in post #29 above. I'm very happy with the picture.
Install in bumper using included hole saw. Run wiring through grommet under jack and connect power to reverse light wire in harness just inside right rear corner (no need to go all the way to the tail light housing). White/Gray = positive. Black = negative. Run video wire along existing harness on passenger side to dash and up to the radio. Plug harness into back of radio.
Go to dealer and hand them these directions:
PARK VIEW REAR BACK-UP CAMERA VEHICLE CONFIGURATION
Vehicle VIN must be updated with the sales code of the added accessory in order to enable system
functionality. Using
the DealerCONNECT website and the StarSCAN diagonstic tool, complete the procedure below:
1. Log on to
https://dealerconnect.chrysler.com
2. In the “Vehicle Option” screen under the “Global Claims System” category in the “Service” tab, enter
the vehicle VIN
and add the sales code XAC (Park View Rear Back-Up Camera) as a “Dealer Installed Option” and code XRV
(Audio and Video Output).
3. Confirm that the new sales code has been successfully added to the VIN.
With the StarSCAN diagnostic tool connected to both the internet (via Ethernet port or wireless
connection) and the
vehicle, follow the steps below:
4. Using the StarScan select the VEHICLE PREPARATION and then select RESTORE VEHICLE CONFIGURATION.
5. Follow the step by step instructions on the StarSCAN to complete the Park View Rear Back-Up Camera
vehicle
configuration.
6. When the Park View Rear Back-Up Camera Vehicle Configuration is complete, go to the Validation
Process to
verify that the vehicle has been updated.
VALIDATION PROCESS
From the “Initial Start Up” screen on the StarSCAN follow the steps below:
1. Using the StarSCAN follow the menu to ECU VIEW, select TIPMCGW CENTRAL GATEWAY, MORE OPTIONS,
ECU DETAILS and then CONFIG INFO
2. Verify REAR CAMERA PRESET- - - -SET is present.
Mine charged me 1/2 hr labor. Some are charging more.
Hope this helps.
Backup camera mount
http://www.extremeterrain.com/raxiom-camera-spare-mount-rax-jstmount.html
