I've been following the battery threads pretty closely lately, and now it's time - or more specifically, Wednesday is the day.
The battery that came in my TJ is an "Econo Power", and was only installed in January. I guess there's a reason "Econo" is in the name! The cables are slightly corroded on the battery end as well, so those will be replaced too. It takes almost nothing to kill it, and the last time, it was about 4-5 days of sitting idle. It runs just a bit over 14V when running, at least according to the gauge on the dash.
I'm not messing around. I'm going AGM. After reading Jerry's and others' accounts of how good they are (plus having heard the same on Harley forums), that part is settled. Other than ease of warranty claims, is there much difference between brands? I'm leaning toward the Die Hard Platinum since Sears is everywhere. Does anyone have reason to suggest another brand instead?
Thanks!
Geoff
NE FL
05 Sport
You are going to replace slightly corroded battery terminals?
A short dunk in a cup of of water and baking soda might save you some trouble.
At the rate they have been losing money, your battery might last longer than Sears does.
...or Pepsi, or vinegar. But my experience (admittedly with motorcycles, but electrons behave pretty similarly) has shown that as battery cables (I think I mistakenly said terminals before) age, they can cause issues. If I'm going to spend $219 on a battery, I'm not taking a chance of being stranded instead by a cable that's potentially corroded under the sheath too. A relatively small investment to eliminate a potential future issue, IMO. I don't want to keep carrying a jumper box with me unless I'm going somewhere more remote.
