I have a 97 wrangler and thinking about pulling the seat out and putting the bolts back in the holes so I don't get the threads screwed up and putting some kind of bedliner paint on the floor. Can anyone recommend what is a good coating to use?
Are you just planning on doing the rear area or the whole interior tub? I would stay away from the aerosol bedliner no matter what. Monstaliner, Herculiner and Rhino (spray gun) are all used a lot. The key part no matter what brand you go with is prep. Sand the surface, get rid of any rust, prime the bare metal areas. And for the bolt holes, just go to the store and buy some foam ear plugs, they work great. You could also just roll up some paper/tape and stuff it in the hole.
