1 - 11 of 11 Posts
Im not looking to do a TT, but I am looking for something that just bolts on. Any suggestions?
Undercover Fabworks makes a skid plate which sits 1.5 inces lower then stock. If you don't have a lift it's a bolt on part, with a lift you would probably need a sye.
zombie & ninja slayer
Barnes off-road makes several different ones
As was stated, UCF makes a great product that is highly configurable. You can also get it in aluminum, if you are worried about the weight. If you go with UCF, spend the extra $ and get both the transfer case and oil pan skid. Here is mine:
x2, UCF makes a great skid. To meet your requirements, I would consider their "no body lift" skid. Since every Jeep is different, you may or not get vibes. I installed this skid early on in my build and at the time I did not have my SYE yet. So to remove the vibes that I did get from the skid's height, I installed a spacer. Note, even with the spacer, I still gained more clearance compared to my stock factory skid.
I went with the UCF.
I went with the Extra Clearance skid and the LoPro transmission mount. NO body lift needed. This wasn't bolt on but it wasn't too hard to make fit either.
If I wanted the NO Body Lift setup and wanted a super simple and easy bolt on deal ... I would buy the Extra Clearance skid and then buy the skid spacers. This way if you change your mind later on wanting a body lift or decide you want to tuck the skid up farther you can just remove the skid spacers and not need to buy a whole new skid.
Don't be afraid to call or email UCF.... they answered my questions quickly when I was trying to configure my setup as I was getting mixed (and just plain wrong) answers and info from the forums.
Here is mine:
i am fluent in kryptonian
sweet i have that skidrow plate. good to know that i cant mount mine to that ucf plate.
1 - 11 of 11 Posts
