got really cold last night and after i got the layer of ice off i noticed a nasty belt squeel than came and went a few times on my way to work. any suggestions where i should start first?
Well it is impossible to tell if your serpentine belt is tight enough but mine squeels everytime after I washed the engine. I give it a quick spay with some Belt Dressing to shut it up.
Make sure your idler pulley is at the right tension and not letting the belt slip.
Donn
I'm thinking belt stretched a bit over time and the cold temps made it a bit more firm. Depending on age, you MAY want to consider a new one. I replaced mine after 8 years when I installed my new alternator and got a belt while I was doing all that. Tighten it down securely enough that you have about 1/2" deflection when pressing on the top of the belt (I THINK that is the tightness - I'd have to double check my FSM).
