does this lift sag at all and does it level it out. Looks like a good liftIf you can squeeze for another 100 bucks. The rubicon express lift is a steal for 599. Good quality lift for a good price.
nothing wrong with it I just want to explore my optionsWhat is wrong with a budget boost? I would run that before I would runs cheap spring lift.
No question, this is the best lift at this price point. You could even go with the version without shocks and add Rancho RS5000X while they are on rebate and get close to the $500 number.If you can squeeze for another 100 bucks. The rubicon express lift is a steal for 599. Good quality lift for a good price.
this is great info, I think I have decided on this lift and maybe those shocks, I have read many reviews on it and it sounds like a deal.No question, this is the best lift at this price point. You could even go with the version without shocks and add Rancho RS5000X while they are on rebate and get close to the $500 number. Rubicon Express RE7121 - Rubicon Express 2.5" Budget Boost Suspension System for 07-15 Jeep® Wrangler JK 2 Door - Quadratec The shocks are like $123 after rebate... RS55329 RS55330 However, I encourage you to look at this thread also. http://www.wranglerforum.com/f202/most-popular-lift-shock-setup-on-wf-1136938.html You should avoid the Skyjacker, Superlift, Trailmaster, etc. cheap lifts with crappy shocks...
I have stock gearing it's a 2012 jeep jk 2 door wrangler sport s so whatever that has I can't seem to find what my gearing isBefore considering 35s, what gearing do you have? Is your Jeep a daily driver or trail only rig?
Go to jeep.com and scroll to the bottom and click on "contact us" and then on the left click on "equipment listing" and put your vin in and it will give you your build sheet and tell you what gears your jeep came with.I have stock gearing it's a 2012 jeep jk 2 door wrangler sport s so whatever that has I can't seem to find what my gearing is
this and bjeepz response is a huge help, I understand how I'm going to have to add on and fix stuff down the road but I'm just leaving towards the RE kit because it's not expensive and doesn't involve a lot of work for the install. Just need to jack it up a bit to fit some big meaty 35sDo not buy a spring suspension based on budget alone. This is just asking for problems. Buy a suspension because it is a GOOD kit. If this means waiting and saving pennies, it means waiting. And also be sure to have a bit of a slush fund - say you get the RE kit on and find out your caster stinks. Then you need drop brackets or control arms. You may need exhaust crossover. You will need a reprogrammer for the tires. For 35s, you should at bare minimum gusset your Cs. And so on. Big Jeeps are a pay to play sport. If you have the 3.21 gearing, I suspect you may not like life on 35s much. Even the 3.73 will be marginal. A regear will run $1-2k, depending where you live.
I am probably going to install this lift kit with the Rancho 5000 shocks. Would there be anything else required or suggested with this kit such as exhaust spacers etc.? Thanks.No question, this is the best lift at this price point. You could even go with the version without shocks and add Rancho RS5000X while they are on rebate and get close to the $500 number. Rubicon Express RE7121 - Rubicon Express 2.5" Budget Boost Suspension System for 07-15 Jeep® Wrangler JK 2 Door - Quadratec The shocks are like $123 after rebate... RS55329 RS55330 However, I encourage you to look at this thread also. http://www.wranglerforum.com/f202/most-popular-lift-shock-setup-on-wf-1136938.html You should avoid the Skyjacker, Superlift, Trailmaster, etc. cheap lifts with crappy shocks...
If '12 or newer, I would suggest a set of exhaust spacers and add a set of geometry correction brackets and don't use the cam washers.I am probably going to install this lift kit with the Rancho 5000 shocks. Would there be anything else required or suggested with this kit such as exhaust spacers etc.? Thanks.
