I have about $800 to spend on a lift kit. Im looking for the best thing i can get for my budget. I want to run 35" tires. Dont really wanna go any bigger than 4" on the lift. Any suggestions?
2.5" is plenty to run 35s There are a lot of good choices out there that would fall within or close to your budget. Just remember the taller you go the more components ($$) you need.
http://www.wranglerforum.com/f202/most-popular-lift-shock-setup-on-wf-1136938.html
With the budget you gave I would suggest you start your research with the Teraflex 2.5" spring lift. The link above is a good place to start reading.
http://www.wranglerforum.com/f202/beginners-guide-to-lifting-your-jk-298665.html
Here is another good link that has ample amounts of info about lifting jk's.
Finally, keep in mind that 35's weigh a bit more than the stock tires do so budget in a tire carrier and (imho) at least c gussets for the added weight.
Banned
$800 in budget will get you the RE lit with shocks,, I don't think you would be disappointed.. At all.....
You can also substitute the RS5000X series shocks and save a little $$. They are coming back with great reviews from respected members. The TF kit is popular for a reason...
I just went with the rancho 3 inch sport lift. With the rebate going I feel like I got a pretty good deal. Now I just need to get it installed.
