Kinda true. The real issue is Apple's MFI vendor certification. Bluetooth headset protocols and the music streaming protocols are exempt, but other Bluetooth protocols are not - including the bluetooth protocols used for OBD-II....
Any ELM327 compatible reader should work (mine is manufactured by LYL?), but it MUST be wifi to work with the iPhone. iOS doesn't support the required bluetooth protocols for the bluetooth readers
Depends on what kind of code you're trying to clear some codes you are able to read but not clear it requires a higher level of access.What's the trick to get the elm327 to clear my codes? I tried it a few time but the codes remained so I disconnected the battery and that cleared them. Does the engine need to be OFF and they key in ACC for it to work? One guy on Youtube did it that way but did not say it needed to be off and another guy did it with his engine running but he did not show the end to see if it worked.
Most require the engine off but the key on, not ACC.Depends on what kind of code you're trying to clear some codes you are able to read but not clear it requires a higher level of access.
When you do clear code, Make sure ignition key is on and engine is off.What's the trick to get the elm327 to clear my codes? I tried it a few time but the codes remained so I disconnected the battery and that cleared them. Does the engine need to be OFF and they key in ACC for it to work? One guy on Youtube did it that way but did not say it needed to be off and another guy did it with his engine running but he did not show the end to see if it worked.
I prefer Engine Link app, not only it could read and clear trouble code. it does live data and allows you to draw multiple pages of gauge layout including emission test report of the engine.which app do you prefer? why?
also, is there a specific diagnostic code reader needed to use with the app? or, can i just get a generic obd-ii adapter?
No you don't need to be in wifi range. It's basically using wifi frequency between your dongle and phone.I just purchased an OBD 2 dongle ( 'iKKEGOL Vgate iCar 2 Mini OBD2 OBD II WiFi Car Diagnostic Scan Tool) i have an iphone 5
what app will be best?
I dont understand the wi-fi vs. bluetooth issue. will i have to be in wi-fi range to use these tools together?
please help
