I’m adding a powered sub to my JKU and already ran the remote on line by coming off the back of the 12v outlet on the dash (switched).
Now I’m looking for “raw” unswitched 12v with at least a 20amp fuse. The PO already added a bus bar to the (+) terminal on the battery and there is 5 or 6 connections there. I’d prefer not to add another one so I’m curious if there is anything on the inside of the firewall that is easy to get to with the dash off.
Thanks!
The battery is still your best choice, along with a big enough wire.
Yea kinda what I figured. At some point I’m gonna rewire this entire accessory system with a marine fuse panel stuffed up under the dash with a single feed. I’ve got front and rear cameras, amp, extra 12v accessory outlet, and CB all making “home runs” to the battery (in addition to ARB compressor and relay/switch panel for all the lights). My OCD is kicking in...
