WHere is the best place to jack up the motor to install a MML ? Thanks.
Brit Nick · Registered Joined Jun 4, 2012 · 920 Posts Discussion Starter · #1 · Mar 4, 2015 Only show this user WHere is the best place to jack up the motor to install a MML ? Thanks.
TNT 02TJ · Registered Joined Apr 11, 2013 · 367 Posts #2 · Mar 4, 2015 Only show this user Just recently did mine. The only place really is under the pan. I set a 2x4 on top of the jack to distribute the weight and had no issue.
Ironhead Jed · Premium Member Joined May 27, 2013 · 7,378 Posts #3 · Mar 4, 2015 Only show this user TNT 02TJ said: Just recently did mine. The only place really is under the pan. I set a 2x4 on top of the jack to distribute the weight and had no issue. Click to expand... or the transmission. make sure you loosen the trans bolts that mount it to the skid before you start
Dextreme · Registered Joined Oct 11, 2011 · 8,401 Posts #4 · Mar 4, 2015 Only show this user Yeah, I duct taped a 8" long 2x4 (maybe it was a 4x4) to the jack to hold the block in place.
