1 - 20 of 27 Posts
Dumb question, is the Sahara a softer or smoother ride than the Sport? I`m getting softer in my old age, apologies to you young guys!
Same shocks, springs, etc.
Unless you count the creature comforts that come with (or that can be optioned onto) a Sahara. Not sure what those are...leather seats, heated seats?
I wouldn't call any Wrangler "smooth."
Okay Okay understand it is relative but I have found a HUGE difference in the tires vs ride quality....and maybe it should have been obvious but....My TJ is 8 years old. My JK is a '12 almost a year old.
Put larger and wider tires on the TJ and it rides so much better, and honestly it has improved so much I would compare it to the JK...now if I did a similar upgrade on tires of the JK how much better would it get????
Good call; the tires definitely make a difference. :thumb:
Newbie here, but from what I remember hearing, the Sahara has larger, 18" wheels (different than tires), thus making for a smoother road/highway drive, as the tires are lower profile, so to speak. Once you start driving a 35" tire with 15" rims, it's a crappy road ride, but better for offroad grip.
I went from 31" x 10.50" on 15" stock wheels to 33" x 12.50" on soft 8's with 26 lbs and 30 lbs. respectively Both all terrains One BFG other Duratracs...just sayin'
Smooth like peanut butter. :D
The Bad Guy
I can't even decide where to begin on how wrong all of that is.
Don't bother. You know that 35s on 15" rims have all that extra sidewall so it makes for a harsh ride. LOL :whistling:
That's funny. :rofl:
Oh thank gawd... I thought I was the only one who was going cross eyed trying to read and re-read that to make sure it wasn't me.
Before I bought my Jeep, I had 225/40/18's on my Kia Soul... and I suffered through 35K miles of what felt like an infinite amount of pot holes. I'll NEVER make that low profile mistake again....
I bought new tires for my Sahara, and the difference was as clear as day. I think they are "Discoverer CTS" tires, I forget the manufacturer, I'll post tomorow. Ride quality all depends in the tires. However, no matter what tires you put on, don't expect to feel like your driving a Bently :p
My 12 Sahara rides a little rougher than my 07 Silverado did. But I wouldnt call it a rough ride. My lifted 79 Blazer with 35s...Now that one Id call rough.
Maybe the answer for the OP is to consider losing some of the "fun" factor in a Wrangler and getting into a Grand Cherokee for the comfort. If you equip it right the GC can still acquit itself pretty darn well offroad while treating you a lot more gently on the road. Of course you won't run that GC with no top and no doors.
For the record, we went the other way from a GC to a JK but it might be a viable option for some.
The 16" base model tires are actually pretty good at absorbing road cracks and little edge bumps. I swapped out those tires for some take-off 32" stock Jeep wheels & tires and I think the 16's ride a little better. It could be the sidewall stiffness or maybe the overwall wheel/tire weight. They are unattractive but they work well.
Two Sahara's with the same options may ride completely different just depending on what springs they ended up with in the spring lottery.​
That being said, your ride could be tuned with a few easy sping and shock modifications.
Retired Mod
I don't know...I would guess that they would be similar with the Sahara having better highway and cornering manners due to the (possible) shock upgrade and the smaller sidewall. Better shocks with stiffer tires?
Something is different in the suspension since the Sport has a "normal duty" suspension, the Sahara has a "heavy duty" suspension, and the Rubi has a "performance" suspension that comes with bright red shocks.
OP - You asked a simple question and got a lot of BS answers... :nonono:
Simple stock Sport S has 17" wheels, the Sahara has 18" wheels. The tire height is close, if not the same for both. You have more sidewall with the 17" wheel on the Sport. All else being equal, the better ride will be with the Sport S. Your Welcome!
1 - 20 of 27 Posts
