1 - 20 of 31 Posts
Along these lines--Would the Spicer 5-760x also fit in a set of alloy chromo shafts?
Knows a couple things...
It's tough to understand how someone could provide you with part numbers without knowing which model TJ you have. Hopefully, you don't have a Rubicon. Because, if you do, the driveshaft joints are not going to fit.
It would have taken you ten seconds to read his Garage profile to know he drives a Sport.
If the chromoly shafts use the OE size u-joints yes the 5-760x joints fit. Some alloy shafts are now coming set up for the larger 1350 size u-joints but most are set up to work with the OE Dana 44 size 297 and 5-760x. The 5-760x is a direct replacement for the OE 5-297 standard TJs came equipped with.
how many do I need to order if I need to replace all of u-joints in the drive train for a 99' TJ Sport?
I'm guessing 5?
7
2 for the Axle Shafts, 3 for front Driveshaft, 2 for rear Driveshaft
Thanks for the feedback. I already have had done the front axle shafts.
So, it looks like I need 5 of them.
Will all 5 (7 if I did axles) be the same exact U-joint?
I'm thinking the problem is U-joints since I am "squeaking" bad at end of day but it stops when I spray WD40 on the U-joints. A lot of the noise went away when I disengaged the transfer case too (Front drive shaft no longer turning?).
Also, I see mixed opinions regarding greaseable (zerk fitting) and the non-greaseable. I just assumed that one would want the greaseable ones but it doesn't necessarily look that way according to various opinions here. It looks like strong support for a higher quality non-greaseable (Spicer?) u joint. Surprising to me as I figured being able to add grease would be a good thing.
I'm mainly fire/dirt/gravel roads (lots of dry dust), large puddles/small creek crossings, maybe a little wheelin' in the future, and lots of suburban road use.
Also.... Sometime the squeaking is the CV ball and socket joint....not just the U-joints. I have had that ball and socket joint bind and cause major problems....broken T-Case.
I have a 2006 LJ as a daily driver. When I first replaced the u-joints, I used greaseable all around. I thought they would last a long time, they're greaseable, right? Well, somewhat quickly some of the zerks would not let any grease go through them. The zerks were the needle point grease gun type.
They lasted for awhile, but not long enough in my mind based on not being able to get the grease into them.
I've replaced them with the Spicer sealed u-joints, no zerks. We'll see how long they last. I expect them to work better.
I had a greaseable 1310 fail with less than 20k miles. Have the sealed versions on their way.
Would this be the Drive Shaft Pinion Yoke or the Universal Joint Yoke?
Does it take 1 or 2 of these?
Should I order either the Strap or U-bolt style?
Thanks.
Ubolts would require you to drill out the holes of the yolk to 5/16. Not a big deal, the metal is pretty soft.
Spicer or equivalent straps are the way to go. The strength of a pair of u-bolts is simply of no benefit in that location, it's the yoke that provides all of the required strength. Plus it's way too easy to overtighten u-bolts which damages the bearing caps and bearings inside.
I don't intend to hijack this thread but i think that sealed Moog u joints are the best. Greasable u joints are cross drilled and inherently weaker. There is an argument that people want an easy to change weak link so they use greasable drive shaft u joints, This is a bad idea as the u joint may fail at high speed and then you have a shaft flailing around at high rpm.
1 - 20 of 31 Posts
