1 - 10 of 10 Posts
I'm thinking of getting some new tires for my '07 Rubicon but I'm looking for something that would provide the most traction primarily for sand. The KM2s seem to have my attention for now. I was thinking about MT/Rs but it seems most people prefer KM2s over them. Of course, they are probably siding with the KM2s just because that's the tire they chose, as they never have any actual evidence to support their statements of why they're better :rolleyes:. I would get paddles but unfortunately they don't handle well on streets... so I've heard. :)
The wider the better. I drive on sand and the AT works fine. If it didn't look so stupid... (and if they even make such an animal)... a 12.50 wide passenger car tire would be good. Jeeps are light and float good on sand with a wide tire.
Nitto Dune Grappler, I have had them, but never in the sand. Ask those Cali Boys, they should know. I would think they are good in the sand with their name. Look killer, but a little pricey...
The KM2s would most likely do terribly in sand. They just dig into everything.
I also read somewhere else about this. Apparently no tread is the best tread. If that were true, couldn't I just hook up some slicks and have the best traction ever?
The dune grappler is nice but doesn't perform well outside of the sand and street.. I've heard of people liking the pro comp AT's for the sand.. But the I myself would think the most highly of these two tires as far as not only a good sand performance but functions on other terrains ok as well..
The Mickey Baja ATZ is a good all around choice I think if sand is you main offroad obsticle.. It will also give a little bit of something on other terrains as well. Mickey Thompson Baja ATZ Radial SLT Tire Reviews
The yokohama Geolander MT I don't know much about but from what little I do know it is used as a tire on the pro comp racing trucks witch run sand and mud races.. I'm gonna trust who ever is putting the stars up on these tires that this tire for a MT if you want something that is also highly capable in other offroad terrain as well as sand then this is your tire
Yokohama Geolander MT + Mud Tire Reviews
My 35x12.5x15" BFG AT KO's do awesome in the dunes. No sinking of any kind, and once they're aired down, even steep hill climbs in sand are a breeze. They behave the same in deep snow, I could float where similar vehicles with mud tires were sinking.
Of course they might not look as mean as MT's, and supposedly do poorly in mud that doesn't matter much with the kind of trails I run.
"Traction" is seldom a problem in sand. Digging and sinking and horsepower are the greater issues, and tires are only 20% of that issue; the other 80% is driver input (technique, skill, tire pressure management).
I've been A-OK on loose dunes with a TJ, 31-10.50 BFG M/Ts at 12psi. Got everywhere I cared to go, and my only real limiting factor was that I lack enough horsepower/acceleration to build momentum for steep stretches.
I've owned KM2s, MTR w/Ks, ProComp extreme MTs, and several other brands of tires, and frequently go four wheeling in the sand dunes. By far, the all time best sand tires I've ever owned was a set of 35x12.50R-17 Dick Cepek FCIIs. The are not so aggressive that they dig in, and they tend to be wider per any given tire size than most brands are. Air them down to 8 psi and they are nearly unstopable. They are MUCH better than KM2s.
1 - 10 of 10 Posts
