What tool to use to cut Jeep TJ Fender
  • Jigsaw
    Votes: 4 21.1%
  • Sawzall
    Votes: 1 5.3%
  • Angle Grinder
    Votes: 9 47.4%
  • Air Nibbler
    Votes: 3 15.8%
  • Bacon
    Votes: 6 31.6%
1 - 20 of 22 Posts
Okay, so by searching I've got: body saw, air nibbler, angle grinder, plasma (no way I can afford one with my other mods going on), jigsaw, and sawzall (don't see how clean this would be lol). Basically I'm looking for a tool that cuts the cleanest. Tell me which tool you used or what you think would be the best and why? Thanks forum!
Not listed and at the time it was a "have to thing"...I used a Dremel with a tiny little cut off wheel....IIRC it was about 3 wheels per side.
I cut the lower portion of the front of the fender "free hand". to "hide" a bent fender that had damage and bondo, before I painted them black...old Pic.
That's a neat little mod that I would probably have done if I didn't plan on cutting the whole thing off :thumb:
How long did it take the cutoff wheels to cut that small section?
It wasn't really that bad.....I spent a Sat morning figuring out how I was going to hide the bent fender/ pulling it "straight" (by hand)/ filling it with bondo/ cutting each side/ and painting it. All told with trips to the store about 3 or 4 hours....probably 15-20 minutes per side. actual cutting.
That's not too bad!
I used a drill bit everywhere my cut need to make a turn then I just used a sawzall to cut from drilled hole to hole. It worked great and was fast.
im using a cutoff wheel, my tubes should arrive tomorrow
Knows a couple things...
I've cut my fenders off on both of my TJs and had the best results with my jigsaw and a fine pitch metal blade. That was after using an angle grinder which worked but was a little harder to make straight cuts with. But then I didn't have to worry about an especially clean cut since the cuts were covered by the new fenders. I use my Dremel tool all the time but I wouldn't use it this much cutting.
Discussion Starter · #15 ·
Thanks for the advice Jerry! I swear I can't look up a mod on here or JF without seeing your name :dance:
I will be cutting mine today, I am good with a angle grinder / cut all my metal/ fabrication work with one, so I will be using one on my fenders as well. Gonna rig up some custom square tube fenders that go down to meet my rockers ( which are custom tube as well )
I used a 4 inch angle grinder with a cut off wheel for my fenders. I used a jig saw for my hood louver install.
I don't think the jig would have cut through the double weld seam on the top of the fender. It would be difficult for the down cut with a jig as well.
Detail Oriented
Bacon. Because bacon.
1 - 20 of 22 Posts
