1 - 16 of 16 Posts
The key for the Bestop lock box can only be removed when locked. You need to unlock with the key every time you retrieve something. It is also impossible to open the door without using the key as a handle.
So, I bought a mailbox lock at Home Depot for about $5 and installed it on the Bestop box. Now the box can be left unlocked and more useable.
Then I found a plastic part with a self-adhesive backing. I pressed that into place and now I can lift the door without retrieving the key. The console lid fits over it very nicely.
Very cool. After using this for a month, what do you think so far? How hard was the lock swap?
I did use the additional screws; but probably not necessary. The box fits perfectly and can't be lifted out easily.
The lock exchange was very easy. It took about 30 minutes.
I had the little handle in a box of miscellaneous stuff.
Ok, I will ask, if you don't intend to keep the box locked then why do you need the box at all?
I have the same box and it works well. I also know a bit about locks and that one you installed can be picked much quicker than the one that came with the box. In about 3 seconds with any other key that is about the same size. Good luck !
I guess ill be the moron that asks--
Im a noob anyway so its ok
If the center console locks why do you need that?
The stock armrest may lock, but it's all plastic. Doesn't take much leverage to bust it off.
1 - 16 of 16 Posts
