hi new to the forum thanks for having me lots of great info on here my question is I have several of the 5.9 jeep Grand Cherokees with the 360s with the bigger rearends with posi traction units are those Front and rear axles better to put under my 95 Jeep wrangler then what Comstock I have the four cylinder with 1.10 gears and it has 35 inch tires 16 inch wheels just want to know if it would be better to retrofit the heavier duty out of the 5.9 V-8 with the factory posi traction into my wrangler need your thoughts and intersite thanks a bunch((((((I have a salvage yard in a full machine shop and great fab skills I know one is Coolspring in one is Leif I have no problem cutting the stuff and welding the plates on for leafspring just need to know if it is worth the time or have any advantage over what I have thanks
I think those Grand Cherokees come stock with the same d35/d30 combo as the wrangler. Find yourself a 8.8 out of an exploder to put under your rear end. Front should be fine unless you plan to really wheel the piss out of it...
