1 - 14 of 14 Posts
For about two years now a project has been slowly forming in my head to build my version of the ultimate adventure truck. I knew it would be based on a Jeep TJ platform for that trucks adaptability and off road capability along with its simple, repairable design and wealth of cheap parts. However I wanted the flexibility of an open bed pickup for small loads as well as the ability to load bikes and gear low where they’re not getting smacked off trees on the way in to adventure. So pretty early in the design process I knew I’d be building a custom top and roll cage to create the ultra short bed Jeep pickup that isn’t currently available on the market. The bed would have a hard tonneau top and truck logistics racking to make it easy to add or remove cargo baskets, spare fuel tanks for the way-back country, and two bike racks. And just to make it stand out a little more while eliminating Jeep’s rust prone fenders, I’m going to cut the stock fenders off entirely in favour of some perfectly round fenders more often seen on tractor trailers. With some creative trimming it’ll give the truck a design nod towards the classic Kaiser and Power Wagon.
Inside there will be a nearly completely customized dash. This is not only to make room for the extra electronics, lights, power, and recovery equipment, but also my custom head unit. Instead of a conventional radio I’ll be repurposing an android tablet. Besides the required mp3 player this will also put navigation, a full set of guages and diagnostics, and a copy of the service manual within easy reach at all times.
I purchased the truck that all this is going into back in the fall – but as you can see from the photo above it needed a little work.
The previous owner got their license on a Thursday, picked up a freshly certified truck on a Friday, and had spun it into a tree on wet pavement before the end of the work week. Inexperienced drivers and short wheelbase vehicles can be dangerous it seems. For me, however, here was a Jeep Sahara with the upgraded drivetrain that had been freshly gone over and certified and only needed some body work. It just so happens I already had another TJ, the one I was originally going to build on, with a good body that needed some undercarriage work. A match made in heaven it would seem. The first purchase was dirt cheap and had a good body on it, but was a bone stock '99 with the 2.5L, the 30RH 3 speed auto, and D30/35 combo - so it clearly needed some attention underneath. The Sahara of course came with the 4L, nv3550 5 speed, and D30/44 axles along with a frame that's in a little better shape to boot. Of course, living in the salt belt, better is a pretty relative term.
After a couple weekends of ripping and stripping in my spare time I had the truck down to a near bare frame – just where I wanted to start.
As it looks today the rear end is even more bare. But it’s the perfect time to go over the frame and clean it up to be worry free for years to come. As well as an amazing time for some undercarriage upgrades. I have a shiny new MBRP exhaust kit as well as a 3-1/4″ Rough Country lift and 1″ Daystar body lift for the truck. The goal is to put some more air between me and the ground for when the trail disappears but not so much as to hurt on road drive ability or need major component upgrades. I also the Rough Country X-Flex control arms to milk more articulation and control out of my truck.
Up to this point however the project has been nothing but destruction and spending on parts. That’s where this weekend was key. At long last I finished the process of destruction and put a fresh coat of paint on the rear axle finally beginning the process of creation.
Not many jeepers can say that their axles are so clean that they shine grey under a photo flash instead of black…but now I am one of them. The beauty of this being a second vehicle means I can take the time putting it together.
Getaway Jeep Rolls On
There was more than a little delay in this project, but things are moving again. While wire brushing the frame I found some a weak spot hidden behind the frame mount for the lower control arm. I fabbed up a quick reinforcement plate, but since the shop I’m working in has some electrical issues I wasn’t able to plug in a welder. I had to wait on a guy with a portable welding setup who did some great work but took a while to connect with. With that cleaned up though, I put in a drainage hole to prevent future issues and coated the rear half of the frame with POR 15 – a rust preventative and paint that’s supposed to be great and is looking very promising so far.
First up was to get the axle back into place – a job easier said than done. Choosing to go with more flexible and more tunable adjustable control arms adds some ability and precision to the truck, but adds more work. Instead of just bolting them in and hoping the Jeep engineers chose a correct enough length even after my modifications, the axle can be setup to the new correct location. First centreing the axle on the bump stops and squaring it to the frame, then setting up the bump stops to maximize the travel of the shocks without damaging them. One final step is to set the angle that the axle meets the driveshaft but can’t do so until I have the actual driving weight on the suspension.
The final hiccup in the axle installation was the trackbar. Used to keep the axle in the correct location left to right. With the lift in place the trackbar needs to be relocated so that it’s fixed length holds the axle in the right place. However that relocation moved the bar into contact with the frame rail that supports the fuel tank when the axle reaches only half it’s suspension travel. Of course a few months ago I passed on a new second hand adjustable rear track bar that would have solved this problem, but at the time I didn’t see the value in that – now I get to pay full price before putting the truck on the road – oh well.
The next step was to bolt in the exhaust – a stainless steel system from MBRP that should last a good long time and happens to have a nice rumble to it without being too loud and seems to give a nice little power boost at the same time. This went fairly painlessly with only a small modification to move the rear most exhaust hanger from the outside to inside of the frame to give a touch of clearance around the after market shocks. If you’re sharp and know Jeeps well enough you may have also noticed the bolts holding the transmission support/skid plate in place now go right through the frame. It’s a known weak spot that the existing bolts that secure to captive bolts inside the frame strip out. A quick and elegant solution I found online is to simply drill through the frame and use a longer bolt with a standard nut on the top side. These bolts are a little long and they were later replaced with shorter ones once I found them hardened to be strong enough, but given that I’m later installing a small body lift as well, adding more space between the body and frame, it probably would have worked anyway.
And with that I finally got to turn the truck around and start work on the front half. Yes, I skipped putting in the fuel tank as I’ll be using the tank out of my second, parts donor truck and there’s no need storing fuel in the garage in the mean time. I also skipped running any of the fuel or brake lines yet as I have a bit of work to do to the body tub before it gets bolted in place. Should that work take longer than expected and this frame ends up sitting longer, I’ll want to re-evaluate the brakes anyway before hitting the road with it.
All the while doing the rear section of the frame, through all the delays, I kept reminding myself that the front would go quickly. After all, I had little more than to unbolt the axle, clean everything up and paint it, then start reassembling again. But then I unbolted the steering box.
Yes, that is a big rip in the frame where the torque from steering oversize tires tried, and nearly succeeded, in pulling the steering box right off. I initially considered a simple fix and simply accepting that the life span of this frame would be somewhat more limited than I thought. In the end though I settled on a proper fix.
The catch came next. The steering box mount is a simple but fairly precise piece. It would take some work to build one from scratch in my somewhat limited shop. So my first step was to look to the online parts catalogs where I found no end of ready to bolt on steering box mounts for Jeep CJ’s and YJ’s where this seems a fairly common problem – but no where could I find a TJ mount. Maybe I’m just ahead of the curve on this problem.
So I started taking some measurements and let my inner engineer come out to design a new, stronger steering box mount and sent the plans off to a friend who runs a machine shop known for doing the impossible with great precision. With that part out for production I’m again at a bit of a stand still on the Jeep, but after wire brushing and cutting off the factory steering box mount it was pretty clear that this was the only route to go. Given the amount of material missing, you really have to wonder how it is that this truck passed a safety certification just before I bought it.
In the mean time, I’m starting some work on the body tub – it needs some attention to the floor supports before moving on to where the truly custom work begins. Other than that, I’m thinking that this project needs a proper name but haven’t found one I like yet – any ideas?
Getaway Jeep Gets A New Sense of Direction - Replacement Steering Box Mount
So a slightly smaller post this time – even though a couple other things have been happening on the Jeep front I wanted to focused just on one problem because it seems it’s a unique one in the TJ world. When I pulled off my steering box I found this:
The steering box had nearly ripped itself right off the frame. Some online reading makes it seem that this is a fairly common issue on CJ’s and YJ’s with oversize rubber and replacement steering box mounts and reinforcements are available right off the shelf – but for TJ’s there’s nothing. Is it a non-issue or am I just ahead of the curve? Of course some east coast salt in the mix doesn’t help things, but either way there’s now a real dilemma – what to do? First step was to hit things with a wire brush to see the extent of the damage. At that point it was obvious there was no fixing or patching the existing. I figured there might not be a solution off the shelf, but that didn’t mean that I couldn’t create one myself. I took some measurements then cut the existing mount off the frame. It was pretty obvious at that point I was going in the right direction.
For one of the highest stress points on the frame, there isn’t much metal left there. What’s surprising is that this frame had recently been certified as safe in this condition. So I cracked out some of my recently dormant engineering background and designed the new mount. I had a friend with a high end machine shop who agreed to prototype out a new mount. The biggest dilemma to building the new mount was finding the solid bolt mounts with just the right inner diameter. They have to be open enough to let the bolt slide freely but tight fitting enough not to introduce play. Rather than try to find pipe with a 12.15mm inner diameter, we were able to just weld in solid rod then machine it to the exact inner diameter. That’s the only part stopping the backyard mechanic from taking this project on I think. If one were really dedicated through they might be able to salvage the material out of the factory mount. With that issue solved, the rest of the mount was designed with over-building in mind. I spec’ed 3/16″ sheet throughout but it was actually built with 1/4″. We probably should have then recessed the bolt faces slightly, but I can tell you that the factory bolts are long enough to take up the excess – but you do have to compensate for the extra plate thickness in the length of the pipes supporting the bolt as their inside edge sets the steering box the right distance from the frame. So if you add a 1/16″ to the plate size, also add 1/16″ to the length of those pipes from the outer mount face. I also made a point to leave the lower corner open to drain mud and water.
With the mount built – it was time to weld it in place. You’ll notice in the photos that there’s also some smaller plates welded to the frame – those are patches to reinforce the tear and the removed rust. With the new steering box mount now welded in place I think this is probably the strongest part of the frame.
http://i0.wp.com/pedachenko.com/blog/wp-content/uploads/2016/06/20160626_164036.jpg
And just like that the frame is ready to go again – the steering box mount fits perfectly and I just need to trim off the lower corner so it doesn’t catch rocks. If you’re having a similar problem – download the steering box mount plans and build you’re own, or contact me to arrange to have one built.
The Getaway Jeep Stands Once More
With the rear end of the getaway Jeep complete, it was finally time to take a look at the front. The first step was to clean up the rust, put down a coat of Por15 to seal up the frame from future issues, and install a motor mount lift. This moves the engine up an inch higher than stock giving me a little more ground clearance to the oil pan and re-aligning the fan with the radiator. More importantly to me though it changes the angle of the transfer case output and the rear driveshaft geometry, hopefully warding off drivetrain vibrations that sometimes come with a lifted Jeep. I’m hoping that with a mild 2-1/2″ lift and this tweak I’ll be fine and at least for now avoid the additional expense of a slip yoke eliminator and carden joint drive shaft.
If you’ve been following the build, you already know that I had some serious issues with the steering gear box mount, but there were some other hang ups along the way as well. During the tear down I noticed one of the front axle shafts was nearly seized solid. I already had plans to replace all the u-joints anyways, but this sealed the deal, doubly so when I pulled what was left of the old bearing out.
Of course though, even this relatively simple job had to fight me. With several weeks of back order waiting on the u-joints, I thought I had it made when they finally arrived. That was until I went to install them and one of the axle shaft joints only came with three of the required four c-clips. I made some calls to the local truck and auto shops to no avail – the only suggestion I received was to order another unit and wait on that all over again. Impatient, I bought a no-name u-joint thinking that I could just use the clips in the quality unit that I had ordered, only to find that the no-name joint used ever so slightly different specs – the c-clip was 0.7mm smaller and would not fit. Finally I tried placing a call to Dana Spicer – the manufacturer – who were so sorry for the mix-up that they couriered a replacement over night from Tennessee. But just to get in a final dig, Fedex managed to screw up the final delivery and instead of arriving at my door I had a two hour drive to pick up the final part – a part with a value of a whopping eleven cents!
With the axle shafts ready to go, I finally turned to re-assembling everything on the front end. I used the same basic method to install the front axle as I did the rear – centring the axle on the bump stops, aligning it to point straight with the frame, setting up the bump stop height against the shock travel, and then re-checking the first two adjustments. That’s when things went sideways though. Every time I cycled the axle through it’s travel it seemed to move forward, as though the control arms had grown and the bump stops where now out of alignment. It didn’t make any logical sense since nothing had changed. So I installed the track bar to keep the axle in more precise alignment, only to find that the mounting bracket on the frame side now hit the differential cover, scraping a layer of fresh paint off it in the process. Thankfully the bracket was heavily over-engineered and even after removing some material from it to create the clearance I needed I’m still certain the cast factory part it’s mounted to will fail first. With all that sorted, the springs were installed as well as the axle shafts, wheel bearings and brakes. For now the original brakes are remaining in place as those are parts that are prone to rapid deterioration and I can’t be certain yet the chassis won’t be sitting some time while the body is prepped, but those parts will all be evaluated and replaced as needed before the Jeep gets saftied for the road.
Now it was on to the steering bits. After having witnessed first hand the effects of a bad case of ‘death wobble‘ – an issue with various causes almost all revolving around loose steering parts – I had decided to replace every last joint and tie rod end with top of the line, brand new pieces. I even decided to replace the tie rod itself even though there shouldn’t be anything wrong with the old one being simply a threaded tube and having no bends – it was the fact that I could get a brand new tie rod for only $35 and save breaking the rust loose on the old one that sold me. As it turned out, that was a bit of a mistake. I got the tie rod through Crown Automotive – usually known for making good quality replacement parts for Jeeps of all ages long after Jeep themselves have discontinued the part. Unfortunately for me, for some reason or another the tie rod ends wouldn’t thread in to the new tie rod. They smoothly turned in about an inch then seized solid. Knowing that they couldn’t possibly be cross threaded after going in that far so smoothly I grabbed a wrench and forced the issue a couple more turns then removed the parts – sure enough it was eating the threads on the new tie rod end. I salvaged the original tie rod from the scrap pile, cleaned it up and sure enough the ends threaded in beautifully smooth without any issue at all. Turns out my shiny new tie rod had been threaded wrong from the factory. So let this be a warning to future builders – don’t trust the Crown TJ tie rod. Luckily my old one was still good and I only damaged about one and a half threads on the very end of one tie rod end so the parts are still more than strong enough, but so much for my completely shiny and new steering bits plan.
Using some information I found online as well as a tip about using lengths of metal stock in place of tire for more accurate measurements, I did a basic alignment right in the garage before mounting tires. Some people online believe that this is just as accurate as a commercial alignment on a Jeep since the very nature of the truck is simple with few adjustments available. Either way I plan to have a commercial alignment done before the truck hits the road as having installed adjustable control arms in place of the factory units does give me control over the caster angle which can be measure more accurately with the commercial equipment. But it will be interesting to see how close this simple driveway alignment came to the real thing. If it’s within reason I know one more job that I won’t be paying someone else to do again. However on future attempts I’ll actually remember to bring better clamps instead of leaving them at home and I’ll use heavier metal arms as these ones required a little care to ensure they weren’t bending.
With that done, it was finally time to mount the front tires, take the truck down off the jackstands, and for the first time since starting this project ten months ago, the Jeep was finally standing on it’s own tires again. It seemed only right to push it out into the driveway and give it a bath, knocking months of accumulated rust and dirt off it.
There are still a few more things to do, like run the fuel and brake lines, change the transmission and motor oils, bolt up the fuel tank and do some final setup on the steering assembly – but other wise this chassis is ready for a body to be mounted to it. I feel like this crazy project is finally reached a stage where it seems achievable.
In the mean time, in it’s continued search for a name, I’ve taken to calling it ‘Project Wanderlust’ since every moment turning wrenches brings dreams of the remote places this rig will be taking me soon enough. We’ll see if the name sticks or not, but either way, one day this truck will be rolling it’s way up the Dempster Highway soon to connect right through to the Arctic Ocean at Tuktoyaktuk.
There's been a couple times along the way that I've questioned why I started in to this bloody project, but one small hurdle at a time and I'm hoping I won't have to revisit any of these fixes for quite some time - if that steering box mount fails I give up...
I'm working away on the tub now and patching a few small holes, building an all new, beefier set of torque boxes since the body mounts were entirely missing after taking a wire wheel to the rust... Now is where I get into all the custom fab work though, so we'll see how quickly it progresses. A few financial hiccups with my Patriot though might have pushed the launch date on this to the spring of '17 instead of the (perhaps still too optimistic) goal of this fall
I was lucky that way in that I practically grew up in a Harley shop. My dad built custom bikes as far back as I can remember - the type that routinely won local shows but just never quite got picked up in national magazines. That meant that I knew how to turn a wrench young and learned that the only thing standing between you and what someone says can't be done is the time to actually do it. This is the first time I've dug this deep into an automotive project though - before this all I had done was a small lift in a Patriot
Discussion Starter · #11 ·
While some other things in life have conspired to make progress on the Getaway Jeep slow down to a crawl – the progress that has been made has been pretty significant. I’ve essentially been working on two different fronts – the undercarriage and mechanical as well as the body work towards the ends of finally joining the two.
I wanted to get as much done as possible on the chassis while I could work on it from above. That meant rebuilding the rear drum brakes with all new hardware, installing the driveshafts, and getting a preliminary setup on the angles of the axles. At least that was the plan.
If you recognise that part – you’ll know that if I were simply installing a driveshaft that I’m doing it wrong. Well it turns out that when I was replacing the u-joints in my rear driveshaft, my makeshift press slipped and did so right at the wrong time that momentum took it’s course. When I looked at the results, my driveshaft was damaged, the metal that holds one of the c-clips in place was crushed and I chose not to risk letting the rest of the c-clip ring do the job. So I grabbed the spare driveshaft that I had from building one truck out of two – only to find out that shaft was a different length and not compatible. My next decision was to replace the stock shaft with a new one or to make an upgrade that I was planning to do a few years down the road – a slip yoke eliminator kit (SYE) and beefier double cardan driveshaft. The upgrade allows for greater differences in the relative height of my engine and transmission from the driven axle which can be used for larger lifts or for tucking the drivetrain higher for more ground clearance. The problem is that the two pieces of equipment to make this possible don’t come cheap and that’s why I had set them aside as a future upgrade. But now with a broken driveshaft, the cost of a replacement driveshaft is almost as high as both pieces of upgraded hardware.
Still, I didn’t want to invest that money just yet and so went looking for anyone in the local community that might have a used driveshaft laying around, or I thought there was a slim chance that someone might be selling both the upgraded driveshaft and SYE for a good price. As it turns out, there weren’t any stock driveshafts, but a guy offered me the upgraded shaft and a complete transfer case with the SYE already installed in it for a great price, the only catch being that it was built for a YJ, not my TJ model, so he told me it would fit except that I’d have to change the output yoke for the front driveshaft from the one he had to the one I already had for my TJ, but since the transfer cases themselves didn’t change in that time that would be a minor change. So I get it all home and test fit it in place and boy was he wrong. The driveshaft was significantly too long to fit. So since I would be installing a body lift and already had a motor mount lift in place, I tried raising the transmission an equal amount, keeping the engine and transmission in the same place now relative to the body, but effectively raising it an inch relative to the axle. Still no joy. So I tried raising the transmission two inches to give even more space knowing that this might have pushed my shifter into the radio when all was said and done. But it didn’t matter because it still didn’t fit.
Now if you look at the total cost of the upgraded driveshaft and the SYE kit, the driveshaft is 2/3 of that cost. Luckily for me at this point, I had paid less for the used parts than the driveshaft alone was worth new, and the driveshaft clearly wasn’t very old. And also luckily for me, SYE kit’s actually come in two different lengths – a short, and a super short. So I ordered up a super short SYE kit new and got to installing it. Now with a working driveline with all the bells and whistles, the only upgrade I’d have for later would be a ‘tummy tuck’ – raising the transmission from the stock position hanging below the frame to a higher point, in extreme cases right inside the frame rails for maximum protection and ground clearance. Little did I know that TMR Customs just down the road from me was busy putting together a brand new website just as I was puzzling through all these issues. Why does that matter? Well in the process of converting the stock Jeep into a short bed pickup, I’d planned to cut two support braces out the stock roll cage. To keep things safe, I had intended to install TMR’s ‘trail cage’ kit, a heavily built upgrade to the stock cage to give better protection to the passengers by building a forward portion to the cage that was missing from the factory and was far superior to the stock braces I was going to cut out. Not that I intended to push this truck to the extreme limits where a complete roll cage was needed to handle rolling the truck out on the trail, but that level of extra safety more than compensated for the parts I was cutting out of the stock safety system for on the highway and allowed my top modifications to go easily. It was one of the pieces I intended to use right from day one and had no reasonable replacement for, I just hadn’t purchased it yet as it was one of the most expensive single pieces I was adding to the truck and I was trying to spread the costs out a little.
Well along with the new website’s launch, TMR was offering some big discounts at the time on most of their selection, including my roll cage plans. So big a discount in fact, that the savings covered the cost of their transmission mount kit which was sort of a little christmas present to be able to do my tummy tuck work right away without any real added expense. That also meant that I was removing the big, stock transmission mount/skid plate. That skid plate causes all kinds of hassles when working on the truck that I’ve now eliminated as well as making routine maintenance much easier, and best of all it also eliminated the problem my father had last winter with his TJ in snow and slush off the road catching inside the skid and freezing his four wheel drive shifter in place. And just like that, the chassis was ready to receive a body again.
In the mean time I had been working on getting the body tub ready in the good weather as it still sat outside, the garage not being big enough for both parts of the truck. The tub off the chassis I was rebuilding had been in an accident and was unusable. That’s where the second truck came into use as it had a perfectly good tub on it. Or at least, what had been a perfectly good tub. As you can see from the photos above of the reinforcement rail on the tub that mounts to the frame, sitting for another two years while the project was launched didn’t help the tub any. It was still mostly good, but these two support rails were write offs. They are available aftermarket, but seemed to me pretty ridiculously priced for what was essentially just two pieces of pressed tin, no thicker than standard body metal. The front’s of these torque boxes as they’re called is quite intricate, but the rear section of them is simply a channel with indentations where the body mounts sit.
Then one day it occurred to me – the indents were essentially irrelevant. They made mass assembly easier by letting the body index onto the chassis, but since I was only building one truck, a few extra minutes in mating the chassis and body was irrelevant to me. So I removed them and just replace the rear of the torque boxes with heavy duty channel I had bent to shape for me at a machine shop, and cut the still good forward torque boxes off the otherwise destroyed tub and welded them to my good tub.
I cut away the existing torque boxes and made some minor repairs to the tub floor where needed by cutting away the bad metal and forming new material in it’s place from flat sheet. Then I fabricated the body mounts to fit inside the torque boxes and welded those onto the tub.
It was more work, but instead of simply welding a nut to the inside of the torque boxes, I decided to give myself some margin for error by letting the nut float in the channel on a large piece of plate which itself was held from drifting too far out of position by some simple tin captures. This gave me an inch of free play for the nut to move inside the channel, but still left a large plate to take the torque when tightening down the tub.
With that done, I put down a coat of POR 15 to seal the underside of the tub and turned it up right side up again.
While the tub was easily moved around on a utility trailer, I strapped it down flat and went to see a friend – and professional welder – to mock in an improved roll cage. With this in place I could finally start to see the shape my new truck would take with a pickup inspired cab roof.
I enlisted some help and finally set the tub on the chassis. A relatively minor step that looks like real progress and certainly got me excited to getting this truck running under it’s own power again.
It’s from here that I started into what was the most intense modification to the truck – the one step thus far that sealed it into going the direction I had planned as a short bed pickup and permanently ruled out ever installing a rear seat again – installing the new back wall of the shorter cab. I was able to cut the cab corners out of yet another (third) Jeep that was destined for the scrap yard. This left me with the clean, round edges to mount a top to just like the back of a factory Jeep. My plan is to modify a factory soft top by essentially cutting the rear seat section out of the top and sewing it back together again. I’ll do a little better than that to minimize seams and potential leaks, but that’s conceptually the plan. I’ve also used my metal break to bend up a tail gate from scratch to fit into this new cab wall that is not shown here. It will be removable to give me more space to cleanly transport things such as a few 2×4’s or pipe in the otherwise short 32″ bed.
The trickiest part of this plan was mating the rounded edge into the otherwise straight belt rail in a way that would end up clean and functional, but still look good and allow proper water drainage for any puddles that form on the new bed hard tonneau cover. Missing in this photo is the new metal to fill in the blank behind the new, green cab wall and the cut original side wall. This metal seals up the original belt line to the rear, squares off the cargo box from the rear, and seals the hole between a straight wall and the rounded cab wall, letting water drain out over the side of the body through the split in the belt rail.
I had been dreading this stage in the build because it was critical to realizing my final vision – but I wasn’t really sure how to pull it off. Cutting up the cab corners to fit around the wheel wells and to mate up with the stock belt rail gave me a pretty good idea how it would come together without irreversibly cutting into my good tub. From there, I made two measurement at the front and rear cuts in the belt rail and otherwise just free handed my cuts with the cut off wheel in the grinder. With a little bit of massaging in the final body job I’m certain it will come out pretty clean though.
Finally I seam sealed my newly sized cab and laid down a coat of bed liner on the floor and back walls. I opted not to bed line the front wall of the tub to make things easier fitting everything to the firewall. I wanted to get the dash and pedals in place to start getting the Jeep back into running shape before fitting the front fenders and finishing the last of the body work.
For the first time since starting to rip apart the crashed Jeep in late October of last year, it feels like the end is drawing near and I’ll finally be able to drive my creation out of the driveway, but surprisingly a name hasn’t fallen on the Getaway Jeep yet. Maybe as the body starts taking it’s new shape it will come to me.
Discussion Starter · #12 ·
The Getaway Jeep Lives
It's been quite some time since my last post on the Jeep and a lot has happened in that time. Life also happened and with everything going on in my life outside of Jeep's, some unexpected deadlines, and surprise failures, there wasn't time it seemed to keep everyone up to date. In fact, those deadlines mentioned even meant I got surprisingly few photos of the Jeep considering how much has been accomplished on it. Now that the Getaway Jeep, tentatively named 'Oscar', is on the road, let me catch you up on how it got there.
At this point in the build it was the heart of winter in central Ontario, which meant work on the Jeep in the driveway was reserved for pretty select days. Instead, I was working on several different minor projects all over the place as time allowed. For one, I was at the point where body parts were finally going back on to the Jeep, and that couldn't happen without a fresh coat of paint. Luckily I had access to some space to convert into a makeshift paint booth and got to work.
The paint I chose is actually regular rust paint from the local Home Hardware. Turns out that they can now tint rust paint to any colour of your choosing. For awhile the Jeep was going to be a brilliant orange, but in the end this shade of green won out. I haven't put a clear coat on the Jeep yet and probably won't. Instead I'll just rely on wax to protect the paint - the theory being that this being regular rust paint, I can just go down to the store and pick up a quart to touch up the paint with a brush when it inevitably gets scratched up. Function over form here.
At this point in the build I found myself jumping back and forth between body work and paint. Some of that body work involved some high tech CAD work (Cardboard Aided Design). Anyone familiar with TJ's knows they are prone to rusting out the front fenders, and mine were no exception. I had four fenders and every one of them had a hole in them. I wanted to solve that problem once and for all as well as do something unique that would give a strong nod back to those classic Kaiser's and they're round fenders. The solution took a lot of time to source and even longer to make work, but the Getaway Jeep now sports round plastic fenders that were originally intended to live over the lift axle of a concrete truck.
I set them high on the body to give lots of room for the axles to flex around underneath and gave them stout, but minimal mounting. The advertising for these fenders involves video of running them over with a tank and watching them bounce back in to shape. I figured in that case they could withstand a few hits against the trees, but I didn't want to mount them too rigidly to hamper that flexibility. Of course I did worry that my minimal mounting might let them flutter on the highway, but thus far that has never been a problem.
The rear's were done to match, but the flat tub side was much easier to mate to than the split and rounded shape of the hood. The front fenders actually split in the middle, with the top half mounted to the hood and flipping open with it giving lots of room to get in next to the engine for repairs.
While on the body work front I installed flush mount truck tail lights as I've always hated the big boxes on the rear end of Jeeps. I also wanted to make the most of a rather minimal box areas. Step one was to turn the standard rear hatch into a drop down tailgate. When combined with the spare tire carrier I intend to build, it's as good as an extra 16" of bed space. The project turned out to be surprisingly simple. Some good, stout hinges from the hardware store get nut and bolted to the tailgate through a single hole bored on the inside wall, and taped and bolted to the heavy wall angle I had already put into the rear of the tub to rebuild the rotted out body mounts.
To make the bed even more flexible, I set the rear of the cab up to be removable, giving me the ability to run long loads right up the passenger foot well when needed. The gate is held in place by pins that were intended to lock house hold patio doors. It gave me a neat and tidy articulated pin that already had a lock built in for extra security (if we ignore that fact that six inches above the soft top is held closed by zippers and velcro).
At this point it was time to prep the tub for paint and bedline my freshly built truck bed.
Meanwhile, my kitchen table had been pressed in to service as an upholstery shop. Early in my build I had come across another Jeeper who was looking for a set of original Jeep seats and was offering to trade even for a set of racing buckets he had mounted to Jeep TJ track hardware. I wasn't entirely sure if I wanted to use the buckets when I first picked them up, but I did know that I had two complete sets of original seats in very good condition so nothing to lose in making the trade. The only downside was that the seats were bright red and badly faded - they would have looked horrible in my green Jeep. So with a trip to the fabric store for some outdoor furniture fabric and many nights cutting and sewing, I was able to give my new seats a much more becoming facelift. I even had a local shop embroider a compass rose into the headrests to further the Getaway Jeep's theme and purpose. While at it, I also stitched in a bunch of MOLLE webbing into the seat backs to give me space later on to get organized.
I also got down to work with a knife and some epoxy modifying the centre dash console. One of the original goals of the Jeep project was to mount a double din android head unit in. To make that happen I had to carve a new hole into the centre console and patch in the face plate from a generic radio mounting kit to return the bevelled, factory like mounting style. While I was at it, I decided to do away with the ashtray and hard top controls I would never use and replace them with a tidy and clean mounting location for accessory light switches and power ports, including USB ports to keep phones charged on the road. To finish it off I gave the whole console a coat of paint to match the body bring the outside in. Of course there are always challenges and this trim piece needed to be pulled in and out so many times while working out bugs that it got pretty banged up along the way. One day it will need a fresh coat of paint and a few touchups.
One of the things that isn't obvious from that last photo is that the bottom switch is a two position switch to control the auxiliary backup lights I would go on to install in the rear bumper. Being an 18W LED light, those lights are a little overkill for use in town as reverse indicators, but I still wanted them to be automatic reverse lights out of town. To make it work I have a two position switch to control them which allows either to completely kill the lights, to turn the lights on full time as work lights in camp, or to slave them to the transmission to come on whenever I'm in reverse (and turn off when not in reverse so I don't get pulled over by the police like my father did around the time I installed these for blinding an officer with his backup lights).
Actually wiring turned in to an extensive part of this project. I wired up an entirely new fuse and relay panel to run auxiliary lighting and the eventual onboard air compressor. I split the factory wiring harness behind the drivers seat to pass neatly through the new cab wall and sent leads into the dash to trigger things like the backup camera. There's another fuse panel added behind the glove box to neatly control all the extra power outlets, radios and other neat gizmos in the cab as well as all new wiring for the sound system as the stock speakers were all thrown away in favour of something a little better suited to the job. As well I had to entirely cut off both the front and rear wiring harnesses and rewire the jeeps lighting at both end from scratch. In the rear I had new taillights, auxiliary backup lights, and a strip light over my bumper to comply with legal requirements (third brake light as well as reverse indicator lights that didn't blind those behind me) all needing to be wired in. As well, I set up all those lights to be easily taped in to with a plug at the top of the box into which I can plug additional lighting mounted to the back of bike racks, overhead roof racks, or anything else I decide to add on. On the front I not only put in my own relays to send full voltage to the headlights (bypassing a known weak spot and boosting my light output) but I set up a series of relays and diodes to convert the factory three wire (park, turn, ground) turn signals into an output for normal, two wire lights. This was a necessity because in doing away with the stock fender I had to come up with a new side facing turn signal. The solution I chose was to mount three penny lights in each fender, out on the edges of the hood. It was a lot of extra effort, but I think the visual result was worth the time.
Next up it was time to fabricate some burly bumpers. The rear is built from 1/8" wall 2x4" square tubing with a receiver hitch and heavy recover points built right in and aligned with the frame. To beef these up even more I added TMR bumper tie in's to further anchor the bumper to the frame rails.
On the front, the stock bumper was reinforced with 1/4" angle iron again with a receiver mount. In time, I'll run wiring and plugs to both the front and rear bumpers to plug in a winch to which is anchored through the receiver mount. The idea there being that not only can one winch be used for either front or rear recovery, but I can keep the weight off the front springs unless I'm in the bush. While I was cutting up the stock bumper, I trimmed the edges to allow them to push off rocks and added a light mount for fogs.
Discussion Starter · #13 ·
The Getaway Jeep Lives cont'd
Getting close to being on the road with the Jeep, I finally tackled one of the projects I was most dreading - modifying the top. All along the build I intended to use a short, pickup style soft top. I wanted a pickup style vehicle, but I still wanted to be able to drop the top on sunny days. Rather than building a custom top completely from scratch, I thought it would be easier to just shorten a factory top. That was why when building out the cab wall I used a set of cab corners from another Jeep tub to match the mounting pattern at the new location. The end result was that my new top would be identical to a full-length, factory top, but with 32" cut out of the middle of it and sewn back together. Simple to say, much harder to do. Thankfully I was able to enlist some help from my mother in this project, a master seamstress herself, and had a second, backup top available in case the first one got screwed up, as well as a couple ruined top pieces to cut up as rough mockups first. It was a lot of cut and test, cut some more and test again. All those baby steps though meant we got a top built that's reasonably good on the first pass. It won't pass for a factory original piece on close observation and I'll probably build a top from scratch for it eventually, but for now it looks great to a casual observer, and with a few more modifications along the way it is finally water tight.
With the top in place and a whole lot of boring but time consuming finish work, I was finally able to drive the Getaway Jeep out on to the street for the first time in 18 months. There was still a laundry list of things to do, but I could start driving it to work out the bugs and retire my Jeep Patriot at long last. The Jeep however had other plans.
When I first bought the truck, it already had 330,000km on the odometer and a questionable at best service history. I went over most everything on the truck during the build - but you may have noticed I skipped the powerplant. While the engine sounded good, I wanted to run it a bit before investing more than a couple seals and some fresh oil in to. As it turns out, I was right.
With only another 3000km on the engine, it developed a nasty knock. Several mechanics looked at it, most of them Jeep specialists, and they came up with several theories as to what could be causing my knock, but no one was confident enough in their diagnosis to pin point a cause. Everyone did agree however that the engine needed a complete rebuild. So here I was in the heart of the summer with a brand new Jeep I couldn't drive and I went looking for another engine.
This one got the complete rebuild service, stripped right down, painted, and every gasket and seal replaced and every bolt checked over. Before long, my shiny new Jeep was looking like a junkyard wreck again.
But in short order it had a new heart as well as several upgrades along the way.
One of the things that still needed to be fixed was that in moving the transmission I had removed the factory skid plate. The truck was never intended to be a serious rock crawler and so didn't need heavy duty protection under there. but I still wanted an extra insurance policy covering my oil pan out on the trail. So with a good sheet of aluminium and some ingenuity, I was able to fabricate a new skid plate to protect my oil pan and transmission.
Beyond that, it was pretty widely known that with even my minimal 2.5" suspension lift and 1" body lift, those big new fender openings made my 31" rubber look pretty tiny. While I had every intention to swap to 33" tires once these ones wore out, again the universe had other plans when I found a wicked deal on an almost new set of 35's and wheels. Yes, I should have regeared my axles, upgraded brakes and done a few other things to put rubber this big on, for now I figure as long as I drive it accordingly with those short comings in mind, I'll be alright. Besides, if something breaks, it's just a good excuse for an upgrade...
But for now, I'm finally driving Oscar out on the streets and through the trails. It never fails to draw a crowd at Jeep events and it's not uncommon to come out to the parking lot to see people looking it over from every angle.
There are still a number of things to get done, like the tool boxes and bike racks in the bed and the new spare tire carrier on the bumper, and some of those things are already in the works, but in the mean time the truck has held it's own on the trails I was able to throw it's way before winter set in again. It even has been able to tear up the white stuff accessing a remote and unplowed cabin through thigh deep powder.
It's a work in progress, but a hell of a fun one.
1 - 14 of 14 Posts
