2010 sahara would be 3.73 or 3.21 i believe, and Dana 30 front diff... I would stick to the 35's. There's more to it than what will just fit physically under the jeepWhat gearing do you have? Do you offroad?
Don't be getting any ideas!!!!Holy carp! Wonder what kind of axle is on that thing?
Probably Rockwells.Holy carp! Wonder what kind of axle is on that thing?
If you wheel at all, stick with the 35's. It's not just a matter of what will fit, it's also a matter of flex. E.g., the tire must fit when they moves up into the wheel well.Sorry if this is in the wrong place or has been asked before, I couldn't find it on my phone.
I have a 2010 Wrangler Unlimited Sahara with a 3.5 inch lift, it's on 35's now. It has stock fenders, would I be able to get 37s on it? Or possibly even bigger? Or are 35s my biggest option without a different lift?
KIIIIIIIIIIND of interested... lol. not for any real world use other than going to mudfest events^ Don't listen to them. I would go 53's. That would look awesome!
Like they said, your gearing doesn't favor anything larger. You'll need C's for sure and should also do sleeves or truss. Might as well do some ball joints while you're in there too.
On the plus side, you have enough lift to fit them, I run 37s on 3" of lift. MMC runs them on 2.5". So if you're willing to re-gear and weld on your axle then go for it!
Edit: 53's
Edit: 53's
