It's fairly consistent but not really constant. I hear it the most when I'm going about 20mph+.Is it constant? There are vac lines at the temp controls maybe one is leaking
It only makes the sound when moving but I don't think it gets faster when going faster. Do 95s have speedo cables?Moving only? Does it get faster when you go faster? Maybe the speedo cable has dried out.
I'm not 100% sure it's coming from the dash. It just seems like it is. I'll try to isolate the sound a bit better.Are you sure it's from the dash?
Could be the seal from the windshield... steering column?
What's the best way to check this? Just put some tape around the area it's coming through the firewall?I have a cricket noise coming from my heater fan. I named him Jiminy. Probably a loose screw.
Seriously though, it could be wind coming through a wiring harness. If your wiring was messed with the plastic loom might have been removed.
