On my 95 yj (no ac) the blower fan runs on heat and defrost, but not on vent. Is there a way to wire this so that it runs when the switch is in the vent position?
amerijeep said:The AC vents are a separate unit, I'm thinking. I'll go check. I don't ever have the top on, so I never use the AC
Yeah, I was just thinking about that. Or maybe I could get one of those hats with the can holder on each side and a fan like a propeller on top.NY94YJ said:I hear that.
How about a Fan that plugs into lighter?
I used one for a while that plugged directly into it, and had a flexible neck.....it did not work to well cuz it was heavy and would rattle out and fall on the floor alot.
I recently aquired another one that has a lead and the fan has a clip....so there should be more mounting options. The On Switch is built into the lead and has mounting points too. Havn't played with it yet.........but I think it should do the trick.....It's not as HOT here in NY though.
