1 - 9 of 9 Posts
Hi, I have a 1997 wrangler sport 4.0 and I saw some videos on where the resistor is behind glove compartment below and to the right of the fuse box. The video I saw showed that you could see the top screw from looking in the glove box opening and then the bottom screw you get at from under the dash. I don't see the top screw and under my dash is a black dome shaped cover so I cant just reach up there like it showed in the video. Is it possible there is another place for it or am I missing something?
My 2002 is in the same spot. Royal pain in the but to get to those 2 screws..I wasn't able to see them either, but after contorting my hands to positions they've never bent to before, I was able to feel them. Putting them back in was much easier than taking them out though.
I believe its a little different for your '97, but I could be wrong. Make sure you are watching a video for your year. Maybe someone with a '97 will pop up
mine is a 1998. i just removed mine last night. it is underneath the glovebox behind a black cover. the cover is held in by 4 phillips head screws. The resistor is held in by two screws as well. About 5 wires going into it.
On my 99 they also said behind the glove box. To me it's more like below. Take the 4 screws off the kick plate and you'll see it. Good Luck
Why would the resistor need replacement. My TJ fan only works on high and I was assuming it was the switch. Is it the resistor?
Ya resistor. It's a 4 path resistor. More resistance for low setting up to no resistance (resistor is bypassed) for high setting. The high resistance paths burn out.
▄▌ee▐▀
Probably is your resistor, the resistor controls all the lower speeds of your fan. High speed is ran direct so that is why it still works
1 - 9 of 9 Posts
