Just curious, does anyone have a solution? I keep going through the upper shock grommets/bushings on the front right side only? Is there an alternative polyurethane replacement or? Anyone else have this issue? Could it be the lower bolts are too loose or too tight? Its kind of strange that its only the passenger side.
Mine was doing the same thing on both sides. The PO had installed a RC 2 1/2 " lift with the RC Shocks. The shocks were so stiff they were destroying the upper grommets. I replaced with Monroe Gas Magnum shocks and problem solved with the added bonus of a MUCH better ride.
From O'Reilly's the part numbers are:
Mon 34658
Mon 34930
Both shocks are 2" longer than the RC shocks. I believe the Monroe's to be 27" up front and 25" for the rear.
Hey! Good to know! I will look into some, thanks for replying. I needed some input. Do you remember how much they were? I can't believe that nobody responded to this question???
