Did you cross any water that went over your wheels?baker3 said:So i was out wheelin when i smelled oil. It was atf so i stopped and checked it and the oil has a milky substance to it. Did i blow it
ATF+4 is what you want.Is there a certain type of atf i need to run in the 32rh?
