I'm wanting to install a 1" bl. I already have the 2"bb and am running 33/12.50/15 tires. This is not a trail rig but it will see a little use on the river, just sand and water generaly less than 2' deep. What are any extras that I should look at buying, any gremlins to look out for ect.
Thanks
Mud
I'd do a JKS 1.25" body with a 1" motor lift. I'm running that set up. 2" BB 1.25" JKS body and 1" Zone motor on 33x10.5 BFG KM2
Motor lif is so I wont have to relocate shroud correct?
Yup and it'll help with drive line angles.
Any issues with transfer case or tranny shifting ? Mine is already a bitch to get into 4L.
Actually my transfer case shifter had some issues before. After I did the body and motor lift it shifts perfect now. I'm assuming you have a 5 speed. Cold mornings 2nd and reverse are a bit stiff until everything warms up. From what I've heard there is a foam ring under the boot, if you remove the roam ring you want have any issues.
Awsome TJ, I just pulled the trigger on the JKS 1.25" bl and bomb proof 1" motor lift.
thanks
thanks
No problem. The JKS is a nice kit.
