Body Mount Bolts Over-torqued
2531 4
I'm a big, dumb animal. I installed Barricade Rock Rails today and for some reason I had it in my head to torque the body mount bolts to 90 instead of 80. After I was done I realized what I had done so I backed them out and torqued them to 80. So my question is do I need to do anything now? Should I replace the bolts?
You're fine. However if you turn left abruptly and the body keeps going straight I retract my statement. (Kidding) your fine but I would check the torque on it next week and make sure it's holding. Did you use blue locktight and if you did, did you tighten/loosen/re-tighten all at the same time before the locktight set, or did you go back much later after the locktight had set? As long as it all happened basically at once Id say your good.
Thank you! It probably sat for 20-30 minutes when it hit me. I'll check it again next week.
· Vendor
If they loosen up when you check the torque you can pull out one bolt at a time and reapply the locktite, then torque to spec. You don't have to worry about major adverse effects from over torquing 10 ft-lbs though. Let me know if you have any other questions!
-Ryan
